Hi-Fi Audio Upgrade for Home Assistant Voice PE (Complete How-to Guide)
Hi-Fi Upgrade for Home Assistant Voice PE!
:large_blue_circle: Audio Comparison / Sample
:large_blue_circle: Features
  • 2x5W speakers
  • >= 3x output volume
  • Massive increase in audio quality
  • One input cable (USB-C power) - everything fits inside the housing
  • Reuses stock rubber feet
  • Open-source 3D design files
:large_blue_circle: License
This project and its associated files are licensed under CC BY-SA 4.0. You may remix this project, but you must attribute myself / this post as the original source/author, and you must retain the same license when publishing derivatives.
:large_blue_circle: Parts and Tools List
Total cost of purchased components: USD $40
You will need the following tools and parts:
  1. A Voice PE unit
  2. :star: “Gikfun 4Ohm 5W Full Range Audio Speakers”
  3. 20AWG or 18AWG wire - 2 colors (Red+Black recommended)
  4. :star: Voice PE Hi-Fi 3D printed parts (1 base and 1 lid)
  5. Screws/Hardware
    a. (Qty:3) M3x10 screws
    b. (Qty:8) M4x8 screws
    c. (Qty:8) M4n nuts
  6. Wire strippers for small gauge wires
  7. :star: “DROK 5W+5W Mini Audio Amplifier Board PAM8406”
  8. :star: “HiLetgo XH-M372 Stereo Audio Isolator”
  9. :star: (Qty:2) Low profile short 3.5mm-3.5mm right-angle audio cable
    a. Example: “Kework 3.5mm Audio Cable, 2-Pack 15cm 1/8” 3.5mm"
  10. Soldering iron (I :heart: my Pinecil!)
  11. Screwdriver (Ratcheting preferred) with these bits:
    a. PH2 - Philips #2
    b. PH1 - Philips #1
    c. H2.5 - Hex / Allen 2.5mm
    d. F3 - Flathead size 3
  12. Solder
  13. (Qty:2) Jump Wire / “Dupont Wire” Male to Female (Red+Black recommended)
(Not shown, optional: 14. Needle nose pliers)
:star: denotes parts that you probably don’t have on your electronics workbench - the total cost of these is roughly ~$40 USD.
A part listed “in quotes and italics” means that you can search for exactly those terms in your favorite rainforest-themed online retailer, and you should find the matching part. I wasn’t sure if these types of links were allowed on the forums so I didn’t risk it. Hopefully I made it really easy to find the parts you need. :slightly_smiling_face:
:large_blue_circle: Electronic Diagram
In case you were curious. :slightly_smiling_face:
:large_blue_circle: Assembly Steps
Clear your workspace.
Cut four ~13cm wire lengths (2 red and 2 black, or any 2 different colors) and strip ~0.5 - 1cm off each end.
Grab the speakers. Find the contact points on one side. There should be two small metal contacts with holes in them. This is the positive and negative connection for the speaker.
(Note: It does not matter which side is positive and which side is negative, but you must do both speakers the same so that you don’t have your speakers out of phase.)
Twist the end of the wire, pass it up through the hole, and solder the wire in place.
You can test to make sure your solder is solid if you can pick up and dangle the speaker by the wire and shake it gently - the solder joint should support the weight of the speaker.
Put the speakers aside.
Grab your Home Assistant Voice PE unit. Make sure it’s completely unplugged.
Make sure the mute switch is UNMUTED.
:red_circle: BEGIN VOICE PE DISASSEMBLY
If you know how to disassemble a Voice PE unit already, or would prefer to follow the official guide instead, you may do so now. You will only need the black mainboard with the scroll wheel, button, and LED diffuser attached, as well as the rubber feet and four small black screws. Scroll down to “END VOICE PE DISASSEMBLY” when finished. Otherwise… read on.
Remove the rubber feet (they are press-fit, so use a fingernail or a flathead screwdriver to pop them off).
Set the rubber feet aside - you will re-use them.
Remove the 4 Philips screws from the base of the unit. Carefully remove the cover from the unit.
Discard or store away the cover and silver screws - these are no longer needed.
Next, remove the four small black screws keeping the PCB in place.
Carefully pull the mainboard out. Note that the built-in speaker is still attached - carefully pull the connector straight out of the board to disconnect it. (There is no clip holding it in place, it should pop straight off.)
You should now be left with the bottom cover of the unit with the speaker inside, the mainboard with the button/ring still attached, and four black screws.
Discard or store away the bottom cover and speaker - these are no longer needed.
:green_circle: END VOICE PE DISASSEMBLY
(Optional: If you also 3D printed a matching replacement button and click wheel - install those now according to the official guide.)
Attach the female end of the jumper cables to the Voice PE mainboard.
:warning: VERY IMPORTANT: Plug the wires in EXACTLY as shown below! :warning:
Face the mainboard upright towards you (so the Home Assistant Voice logo is upright).
Connect the female side of the black (or ground color) jumper cable to the top left pin on the LEFT pin group.
Connect the female side of the red (or power color) jumper cable to the top left pin on the RIGHT pin group.
Optional step: Dab some hot glue around where the jumper meets the mainboard to hold it in place.
Plug one of the 3.5mm cables into the mainboard.
Place the mainboard with the three cables attached into the 3D printed base. It only goes one way. Refer to the picture for correct orientation.
Fasten the four small black screws into the same holes they were previously removed from. You will feel a bit of resistance as the holes underneath are not threaded, so you are “tapping” the screw in. Ensure the screws go all the way down and are snug. Do not overtighten as this can strip the plastic under the screw.
Flip the unit over and ensure that the control ring and button still work, and that the microphone gaskets are visible through the small holes on either side. (Again, it only assembles one way, so if something doesn’t line up, I don’t know what to tell you…)
(Note: Currently there is not a space to mount the isolator module inside the case - this will come in a future iteration. I did not realize a ground loop isolator would be required until after the 3D model was completed and I have not had time to go back and revise it.)
Set aside the unit. Grab the amplifier board.
Prepare the board by loosening/unscrewing (3 turns) all 6 of the terminals on the board. Do not overtighten (over-loosen?).
Take the jumper cables connected to the Voice PE mainboard and connect them to the power side of the amp board (the side with only two terminals). Connect the red wire to the + terminal and the black wire to the - terminal. (The board is labeled.)
Next, grab the ground loop isolator module. Plug the 3.5mm cable from the Voice PE mainboard into one end of the isolator board. Grab the other 3.5mm cable, and connect the other end of the isolator board to the amplifier board’s 3.5mm jack.
When finished, it should look like this.
Next, using the three M3x10 screws, mount the amplifier board to the side of the 3D printed base. See the picture for correct orientation. (When the front of the unit is facing you - the completely flat side - the amplifier should be oriented with the 4 terminals on top, and the volume knob on the right.)
For the top 2 screws, you should be able to screw them in from the top opening, as shown in the picture.
For the bottom screw - there is only one, on the right side of the amp board when facing it towards you - use the hexagonal hole at the back to insert a screwdriver to tighten the screw, as shown above.
Next, grab your speakers.
Place one over the speaker grill. There is a groove, so you should be able to feel when it is set in place.
Take an M4x8 screw and an M4n nut and fasten one of the top corners, with the screwhead on the outside of the unit, driving inwards.
Important Tip: You should not need a socket or pliers to hold the nut! Your thumb/finger should be enough, and once the screw is tight, you can tighten/twist the screwdriver in a “jerking” / quick motion. The nut should grab onto the mounting hole of the speaker after a few jerks, and set into place. You’ll know that it’s set when the force required to tighten it increases significantly. I have assembled 2 of these units now with no socket/pliers/wrench to hold the nuts! It is all about the technique. :slightly_smiling_face:
These screws/nuts should be fairly tight (near the limit of a hand tool), but not overly so.
To get the bottom screws, after you get the top ones in place, you can hold the unit sideways, and balance the nut on your finger. Press the nut up against the hole and get the screw started.
You can also try to hold the nut in place using needle nose pliers. The hole near the amplifier board’s volume knob is the only one that gave me a bit of trouble. Persistence is key - you can do it! :slightly_smiling_face:
After securing one speaker, secure the other one in the same manner.
Once completed, your setup should look like this.
Next, connect the speakers to their respective terminals on the amplifier board.
The board is labeled and visible looking down from the back side of the board.
Wire the speakers in a cross pattern - the terminals are on the opposite side to where the speakers are. So in the picture above, the left speaker is wired to the terminals on the right (opposite) side to where the speaker is.
The speakers are wired backwards on purpose! The ground loop isolator board reverses the L/R audio channels, therefore it’s necessary to connect the “right” speaker to the left input of the amp board, and vice versa.
Time to test it!
Plug in the Voice PE and wait for the LED lights to illuminate.
Turn on the amplifier by rotating the black knob until it clicks. Increase the volume (continue rotating the knob) until it won’t rotate any longer (100%), and then rotate it back 1/4 of a turn (~80%). This ensures that you can set the Voice PE’s volume to 100% without distorting the audio. (100% on Voice PE and 100% on the amp can cause audio distortions.)
Play some music with something like Music Assistant and make sure it sounds good! (Note - the bass might be lacking a bit - the sound quality increases dramatically after you close the bottom cover. Acoustic resonance and all that. :grin:)
If you’re satisfied with everything, pop the bottom lid on (note the small tabs line up with small grooves in the side of the housing). It’s a rectangle, so it only goes on one way. It should click into place.
Install the rubber feet by gently pressing and twisting them into position - they should fit snugly and be identical to the original Voice PE, as the holes were modeled off of the base of the stock unit.
:white_check_mark: That’s it! You did it! Enjoy high fidelity audio from your Voice PE unit. :smile:
:large_blue_circle: FAQ
  • The microphone doesn’t work / it’s muted!
    • Open the cover, reach in and flip the mute switch. You may need to use a small screwdriver. You may have accidentally flipped it during assembly. This is the mute switch in the unmuted position:
  • I can’t access the mute switch?
    • Not in the current design, no. Personally, given the open source and local nature of Voice PE, and the fact that it also has software mute capability via HA, I’m not really worried about the hardware mute switch. But if you are, feel free to modify the 3D printed design to accommodate a mute switch of some sort. :slightly_smiling_face:
  • Can the Voice PE mainboard really drive speakers this large?
    • Yes, while the speakers are rated at 2x5W (10W at 5V is 2 amps), I measured the power difference when audio was playing vs. when it wasn’t, and it only draws an additional ~0.3A, which is within spec for the GPIO pins of the mainboard. (See power meter image below - left half is no music, right half is music.)
  • There’s no place to mount the ground loop isolator? It’s just dangling in there?
    • Yeah, sorry. The ground loop isolator was a last-minute addition, and I wasn’t sure if I was going to use the 3.5mm version or the bare version (that you have to solder yourself). This was easier. V2 of the 3D printed housing will have a space to mount this board.
  • Why are there two hexagonal holes on the back?
    • For two reasons. First, it improves airflow/resonance for the speakers. Second, if you can’t find right-angle low-profile 3.5mm cables, you can take a regular 3.5mm cable and plug it in using the hole, then U-turn the cable back through the same hole. It will protrude from the back a bit, but that’s okay!
  • Your acoustic chamber isn’t very good / could be optimized to increase audio quality.
    • You’re right, I’m not an audio engineer. :slightly_smiling_face: I wanted the unit to be relatively small and easy to 3D print (no supports!) and assemble. But if you think you can improve the acoustics by adding different air channels / ports, feel free to remix the design!
  • Can I EQ the sound?
    • Not with hardware, no. But Music Assistant now supports a software parametric EQ - you could try that!
  • I don’t like these speakers / I want to use different 2x5W speakers.
    • There are other speaker deisgns/configurations out there (for example, search “MakerHawk Double Cavity 5 Watt Speaker”), and modifications to the housing could support other speakers in the future, yes.
  • This still isn’t as good / loud as <insert tech giant voice assistant device here>!
    • Yeah, it’s not. But I couldn’t find a more powerful readily-available amplifier board that was that tiny, and even if I did, I’m not sure the Voice PE mainboard would be able to drive anything more than 10W total anyway.
  • This is fantastic! Can I support you with a donation / subscription?
    • First off, thank you! However, I am financially stable, and I do this for fun in my spare time as a hobby. :slightly_smiling_face: I would encourage you to make a charitable donation with the money instead.
:large_blue_circle: Comments / Suggestions / Feedback are welcome!
And if you make one yourself, I would love to see it! Please post a picture!
Additional discussion can be found on this Reddit thread.
To break the ground loop, I suggest using a digital device:
There are solder pads on the back side.
Use the image search to find it.
If you don’t need very high volume, you can isolate the power line using the b0505s-1w/2w/3w component.
I often use this method
Could a larger power supply be used to supply power to both the PE and speakers too allowing for higher power speakers?
The analog ground loop isolator works perfectly well, what purpose does a powered/digital one have over the passive one? I’m not understanding the purpose of this device.
In theory, yes. In practice, USB-C is tricky to mess with as there are 12-16 wires inside the cable (versus USB 2.0 which has 4), so finding a way to split or siphon that power AND have that solution fit inside the existing box is a difficult problem to solve.
So, it was easier to pull 5V+GND from the ESP32 GPIO pins and call it a day. :slightly_smiling_face:
Totally understand.
I am no electrical engineer so would have no idea how to implement it but that’s where my thought was. Have a higher input (DC barrel or something) that can step down to power the PE and then the speakers too. Again, I have no idea how that would be implemented and probably would require some custom PCB work. But it’d be cool to see something like specifically for HA and Music Assistant.
You don’t need more voltage and extra power for the PAM8406 (and similar chips). In normal operation it will consume 1-2Watt.
10W is marketing, these are the values you can get for a 2ohm speaker with 10% distortion and additional active cooling.
If you decide to use the tpa3116 (one of the versions of the chip that are often used in portable speakers), then you can use a 12-24v power supply (20v 1.5A fast charger is great if you add a trigger), and through a DC-DC step down converter to 5v supply power to the satellite board. Or you can combine this with ground loop breaking using the b1205s-2w
It’s easy enough to implement, but it doesn’t make sense for small speakers.
I agree, that would increase audio quality/loudness for sure, but I had two requirements for this project in particular:
  • It must fit in a relatively compact enclosure
  • It must all be fed by a single USB-C connector
I’m not sure that all of those components would satisfy those requirements. :smile:
Volume Update
At high volumes, the speakers can clip and pop, causing distortion (and, obviously, this is not good for the speakers themselves either).
I found that, if you use Music Assistant, setting a parametric EQ setting on the speakers can get you more volume without the clipping. This seems to get me about +10% volume total. Not bad!
Here’s the EQ profile I applied to all of my “Voice PE Hi-Fi” speakers.
You can grab the profile from this post and import it into your own Music Assistant if you’d like to use it as a starting point.
Yeah, I know that this EQ muddies the audio quite a bit, but removing the lower frequencies was what stopped the distortions at high volumes, and the speakers, being so small, were too heavy on the highs, so pulling those down a bit rounded the sound out. You can always tweak this to your liking! :slight_smile:
Preamp: 0.00 dB
Filter 1: ON PK Fc 20000.0 Hz Gain -8.70 dB Q 0.200
Filter 2: ON PK Fc 2825.0 Hz Gain -2.40 dB Q 0.700
Filter 3: ON PK Fc 88.0 Hz Gain -7.40 dB Q 0.300
Filter 4: ON PK Fc 20.0 Hz Gain -15.00 dB Q 0.800
Copy and paste this into a .txt file, save it, and press Import APO/REW Preset and it should pull in these settings for you.
Absolutely incredible find! Kuddos for the effort. I’m still curious if anyone made the comparison with a Google Nest Mini in terms of sound quality (loudness comes 2nd as I would assume that’s enough for light playback)?
I know you mentioned it doesn’t compare to [name your brands], just curious about your genuine opinion @qJake ?
The reason I’m asking is that I really wanna get rid of that nest mini, but currently the sound is just not enough on the PE, but your setup could change that… Living in the philippines, the total cost of parts is roughly 12 bucks, that’s very hard to pass on considering I own a 3D printer…
Question 2: is it somewhat reversible ? I havent noticed any destructive process but just to be sure.
Once again, thanks a lot for sharing this with the community, it definitely tickled my (evergrowing…) To-do list of projects!
@bchevreau I would say that it’s about 80% of the way there to commercial offerings. Part of the issue is that I’m not an acoustic engineer :sweat_smile: so I know that the design could be improved. For example, the seal between the lid and the base is not good enough / has a gap, if I press down on it to seal the gap, the sound quality improves a bit because the bass can resonate better. I need to iterate on the design to create a better lid / locking mechanism.
And yes, it is 100% reversible - the only thing that plugs into the HA Voice board are power, a 3.5mm audio cable, and two Dupont cables which just “plug in” to headers on the board and can be removed effortlessly.
Good luck! :slight_smile:
anyone knows what amplifier chip is used in stock voice pe? Is there a schematic I could check?
Great project, thank you for sharing this. I am about to give it a try and already ordered all necessary parts.
But i was wondering if you already had the chance to refine the 3D model regarding the isolator mount? Beside this, the general appearance of the print seems a little too functional for my gusto, is there any chance you could give it a design update? Or share the model in a format so i could try redesigning it? I am fairly new to 3d printing and CAD and didn’t manage to disassemble the .stl file.
I have not had a chance yet, but let me see if I can get around to it in the next couple of days. If I do, I will post an update here as well as on Printables!
@qJake may I recommend that you look at https://makerworld.com/en/models/1169821-home-assistant-voice-pe-fabric-enclosure for some inspiration?
I’ve already printed it, and the base shell is generic enough to support modifications so that a 40mm speaker fits (in fact the Gikfun 5W speakers are a perfect fit on the sides, and the cavity inbetween can easily fit the amplifier board (potentially even with the knob exposed!) as well as the passive isolator.
It does, however, require a few small changes:
  • A new top cover design (basically merging your model’s mounting for the PCB, with the official 3D printable case’s top + adding a rim the same size as the official case’s walls, for a tight fit). This could include a screw-on addon for the isolator.
  • A custom insert for mounting the speakers (given their vicinity though, I think modifying the base for 2x 40mm mounts is a better option)
  • The base model needs to be modified to only expose the USB-C port, and allow space for the 3.5mm jack (this means the port slot on Plate 4 also needs to be modified).
  • Modifying the feet base board (linked in the comments) to include a mounting spot for the amplifier board
Fortunately, all the models’ CAD files are available on MakerWorld, so modifying them should be relatively straightforward :slight_smile: I’ve already started working on it.
Benefits:
  • Neat, compact design, with cloth/mesh cover in mind
  • Access to the mute button (albeit a bit clunky)
  • Space for multiple speakers and speaker layouts, allowing different inserts to mount them
Downsides:
  • Default design uses the official case, making it a bit iffy to use with the 3.5 adapters
  • Space between speakers is “just enough” to not have the magnets push them apart (possible magnetic interference source?)
in the meanwhile, i came up with an own design which i will publish soon, but first i need to implement some minor changes.
however, after assembling everything, i noticed this constant noise coming from the speakers. this noise is quite loud when i power the device and then turns down, but is still audible, constantly. depending how much i open the spincontrol on the amplifier board, the sound gets louder/quieter. does anyone know why this is, does anyone else experience this?
I have not experienced this. Have one unit built and it’s a huge improvement in audio quality over the standard PE. The only issues I’ve had with it was that there was a lot of vibration at first as sound was playing. I tightened the screws and now it’s gone for the most part. There’s still a bit of a vibration sound when there’s heavy bass and I think it’s because of the lose component.
I’d very much be interested in checking out your design so please share :slight_smile:
I’ve looked at your design multiple times, and it looks like audio comes out of the PE via 3.5mm and into the isolator. Then that goes into an amplifier into the speakers.
Are you noticing distortion? I’ve compared my PE against other 3.5mm jacks and am getting a ton of distortion the other devices don’t have. The ground loop is also an issue, so I tried battery-powered speakers, but it sounds the same.
When the amp volume is maxed out, yes, there is distortion. I keep the amp knob around 80-90% (basically, I play a very loud song at 100% volume on the PE device, then dial back the amp knob until it stops distorting). This is an unfortunate side effect of these components being combined together (budget amp, budget speakers), as well as the line input from the PE device probably being a little more “hot” than what the amp is used to.
Dialing the amp volume knob in removed distortion for me.
For the ground loop isolators, I included those in the design not due to audio distortion, but rather because there was a significant hummm coming from the speakers without it. And when it’s sitting on my desk about 12" from my ears, that gets quite annoying. :wink: A GLI fixed that.
From what I saw, it was the Voice PE itself clipping. Lowering the volume wouldn’t fix it.
I’m curious if you mean you dial back the Voice PE’s volume, and there’s a point at least you don’t see it clipping.
I’m wondering if you can use Music Assistant DSP to help (but that’s not a permanent fix) or if there’s a way in Home Assistant to fix it via the ESPHome integration.
It’s been months since I last tested clipping via the 3.5mm jack, but I the things I’d test are:
  1. Seeing if it’s fixed at different volume outputs (amp issue).
  2. Seeing if the source audio level is the problem (DAC issue).
If I remember correctly, it’s actually the latter which means it’s not able to be fixed no matter what you do (unless you bypass the DAC using the Grove port).
What’s a ground loop isolator? Does it play back the ground noise in reverse polarity to cancel it out?
Also yes, any buzzing or humming like that is super noticable up close. I had to change back to a less-good amp on my PC because the good one was too sensitive and picked up something.
