Hi everyone I joined today as I ordered a blue unit and I’m keen to learn about home automation. I have a number of smart devices and also use Roon and Plex.
No idea where to start, anyone have any ideas?
There’s a list here of all the core integrations you can use with home assistant, worth having a look to see if what you have is compatible: https://www.home-assistant.io/components/
Even if it’s not listed there you may find a custom integration for your device (Google "home assistant + your device name).
As you have a blue unit you can skip the install instructions and start from here: https://www.home-assistant.io/getting-started/automation/
Thanks, I will definitely take a look. Not sure when my blue ships though.
