Parts List:
- HID Proxpro 5352 RFID Card Reader
- NulSom Inc. Ultra Compact RS232 to TTL Converter with Female DB9 (3.3V to 5V)
- Lolin Wemos D1 Mini esp8266
- Lolin Wemos D1 Mini Power Shield
- Lolin Wemos D1 Mini Relay Shield
- Tripler Base for Lolin Wemos D1 Mini
- Male RS232 DB9 connector
- 2x DB9 hoods
- Five conductor cable, HID recommends “Alpha 1295 C”
- 12V two conductor cable
- 12V 2.1mm Power Pigtail
Solder the D1 Mini parts together, being careful to get the orientation right. So it looks like this:
Instead of this:
Flash a base ESPHome image on the D1 Mini via USB and then remove the USB and plug in the 12V power supply via the pigtail. Test that it is showing up on the network and ESPHome can work with it.
Wire the RS232-TTL converter by hooking GND to the D1 Mini GND, VCC to the D1 Mini 5V, and OUT ARROW of the TTL side to the TX pin of D1 Mini and IN ARROW of the TTL side to the RX pin of the D1 Mini. The reason I reverse this is that supposedly the D1 Mini will spew some debug upon every boot out the TX pin. You don’t want anything connected to it reacting to this. I don’t think the ProxPro receives anything, but it doesn’t hurt to reverse these and set them up proper in ESPHome later.
When done, it should look something like this:
Now wire the male RS-232 pins to the ProxPro:
- DB9 pin 2 DCE TXD to TB1 7 - RX-/RD
- DB9 pin 3 DCE RXD to TB1 6 - RX+/TD
- DB9 pin 5 to TB1 3 SIG GND
- 12V+ to TB1 1 DC+
- 12V- to TB1 2 GROUND
Everything hooked up:
Make sure the DIP switch settings on the ProxPro are for RS232 communications. The RS232-TTL converter will convert its signals down to what the D1 Mini understands.
While working on this, I originally tried to find a “custom component” for ESPHome that would send all serial communications to a TCP port. This stream server component (serial-over-wifi) does just that, and does it well. However, I decided that I wanted something integrated into Home Assistant, so I wrote my own custom component to grab the readings from the ProxPro and send them to a sensor.
Basic ESPhome config:
esphome:
platform: ESP8266
board: d1_mini
includes:
- uartline.h
wifi:
networks:
- ssid: "My Wireless Network"
password: "my-wireless-network-password"
logger:
baud_rate: 0
api:
ota:
uart:
tx_pin: RX
rx_pin: TX
baud_rate: 9600
text_sensor:
- platform: custom
lambda: |-
auto rfid = new RFIDSensor(id(uart_bus));
App.register_component(rfid);
return {rfid};
text_sensors:
uartline.h:
#include "esphome.h"
class RFIDSensor : public PollingComponent, public UARTDevice, public TextSensor {
public:
RFIDSensor(UARTComponent *parent) : PollingComponent(100), UARTDevice(parent) {}
String line;
String lastpublished = line;
void setup() override {
// nothing to do here
void loop() override {
while (available() > 0) {
line = readStringUntil('\n');
line.trim();
ESP_LOGD("custom", "RFID read %s", line.c_str());
yield();
void update() override {
if (line != lastpublished) {
publish_state(line.c_str());
else {
if (lastpublished != "WAITING") {
delay(1000);
publish_state("WAITING");
line = "WAITING";
I put the “WAITING” state in, because if someone needs to scan their card twice, the sensor won’t register the change unless there is something in between. The ProxPro has a pretty slow cycle, like 2 seconds, so I figured a one-second state was plenty for Home Assistant.
I run 12V directly from the green wire connector on the Power Shield to the Relay Shield of the D1 Mini. This is what I use to power/unpower the maglock on the door. The D1 Mini could also support a PIR motion sensor for unlocking the door when people come to one side of it, and/or environmental monitors.
This is an example of what the Home Assistant automation looks like:
- alias: RFID Multiple
- platform: state
entity_id: sensor.rfid
to: '012345678901FF'
- platform: state
to: '012345678902FE''
condition:
- condition: state
entity_id: switch.frontdoor_maglock_power
state: 'on'
- service: notify.notify
data_template:
message: >
{% if trigger.to_state.state == '012345678901FF' %}
Pete opened Front Door
{% elif trigger.to_state.state == '012345678902FE' %}
Bob Dobbs opened Front Door
{% endif %}
- service: switch.turn_off
entity_id:
- switch.frontdoor_maglock_power
- delay: "00:00:08"
- service: switch.turn_on
entity_id:
This automation gets unwieldy if you have hundreds of cards to read. I welcome suggestions as to how to convert this type of thing to an external db or other simplification.
