Hello all
i’m swapping a couple of devices over to a hidden network and cant seem to get it to connect to router, ssid is hidden if i expose it device connects fine.
there is no example in esphome docs but there is a mention of of the setting which i assume i’ve done wrong, it is compiling but still no connection.
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
networks:
- hidden: true
ssid: 'homenot'
- ssid: 'homenot'
password: '*******'
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
light:
- platform: neopixelbus
type: grbw
variant: SK6812
num_leds: 103
pin: GPIO3
effects:
- addressable_color_wipe:
name: Color Wipe Effect red B to T
colors:
- red: 100%
green: 0%
blue: 0%
white: 0%
num_leds: 1
add_led_interval: 50ms
reverse: true
name: Color Wipe Effect red T to B
colors:
- red: 100%
green: 0%
blue: 0%
white: 0%
num_leds: 1
reverse: false
name: Color Wipe Effect black B to T
colors:
- red: 0%
green: 0%
blue: 0%
white: 0%
num_leds: 1
reverse: true
name: Color Wipe Effect black T to B
colors:
- red: 0%
green: 0%
blue: 0%
white: 0%
num_leds: 1
reverse: false
name: Color Wipe Effect white 100% B to T
colors:
- red: 0%
green: 0%
blue: 0%
white: 100%
num_leds: 1
reverse: true
name: Color Wipe Effect white 100% T to B
colors:
- red: 0%
green: 0%
blue: 0%
white: 100%
num_leds: 1
reverse: false
name: Color Wipe Effect white 25% B to T
colors:
- red: 0%
green: 0%
blue: 0%
white: 25%
num_leds: 1
reverse: true
name: Color Wipe Effect white 25% T to B
colors:
- red: 0%
green: 0%
blue: 0%
white: 25%
num_leds: 1
reverse: false
name: Color Wipe Effect muilty B to T
colors:
- red: 100%
green: 0%
blue: 0%
white: 0%
num_leds: 5
- red: 100%
green: 50%
blue: 0%
white: 0%
num_leds: 5
- red: 100%
green: 100%
blue: 0%
white: 0%
num_leds: 5
- red: 0%
green: 100%
blue: 0%
white: 0%
num_leds: 5
- red: 9%
green: 58%
blue: 100%
white: 0%
num_leds: 5
- red: 41%
green: 2%
blue: 100%
white: 0%
num_leds: 5
- red: 61%
green: 0%
blue: 100%
white: 0%
num_leds: 5
reverse: true
name: Color Wipe Effect muilty T to B
colors:
- red: 100%
green: 0%
blue: 0%
white: 0%
num_leds: 5
- red: 100%
green: 50%
blue: 0%
white: 0%
num_leds: 5
- red: 100%
green: 100%
blue: 0%
white: 0%
num_leds: 5
- red: 0%
green: 100%
blue: 0%
white: 0%
num_leds: 5
- red: 9%
green: 58%
blue: 100%
white: 0%
num_leds: 5
- red: 41%
green: 2%
blue: 100%
white: 0%
num_leds: 5
- red: 61%
green: 0%
blue: 100%
white: 0%
num_leds: 5
reverse: false
- automation:
sequence:
- light.addressable_set:
range_from: 25
range_to: 70
red: 0%
green: 0%
blue: 0%
white: 0%
- addressable_lambda:
name: "My Custom Effect"
update_interval: 16ms
lambda: |-
it.range(25, 45) = light::ESPColor(0,0,0,0);
it.range(65, 102) = light::ESPColor(0,0,0,0);
binary_sensor:
- platform: gpio
pin: D1
- platform: gpio
pin: D2
- platform: gpio
pin: D5
- platform: gpio
pin: D6
many thanks
