Hi there!
Did some research before opening this thread, but can’t solve my problem. I have my Risco alarm integrated with its new component added in 0.115 and it’s working great, but I can’t hide the keypad on Lovelace. It takes a lot of space and I am not using PIN codes to arm/disarm it.
Any way to hide it permanently? Thank you!
Have you found a way to hide they keypad yet? I am wanting to do the same thing
Sadly no. I tried creating a template alarm panel but same problem
anyone figured out? thnx
Same here…alarm panel key pad is not required as code is already added in the configuration file.
Any solution to hide it…?
Super weird - mine had always been hidden (since ‘22 or so?) but just this last week is now a big exposed keypad in my dashboards. I would definitely prefer to go back to the older style simple arm/disarm button.
Probably cause by the new feature in 2024.6, that code arm required = true
I see the same, seems my alarm panel card is now also presenting a huge keycode , anyone figured out how to disable?
