is it possible? totally brakes things like Grafana
I’d like to know too as I have a similar issue with YR weather cards:
I’ve investigated this a while ago and found the part responsible for it but couldn’t remove it permanently, maybe cause I got Hassio manually installed, it’s located in ha-camera-card.js:
https://github.com/home-assistant/home-assistant-polymer/blob/master/src/cards/ha-camera-card.js
lines:
<div class="caption">
[[_computeStateName(stateObj)]]
<template is="dom-if" if="[[!imageLoaded]]">
([[localize('ui.card.camera.not_available')]])
</template>
</div>
In Chrome right click > inspect > select element > “div caption”, removing it hides grey bar but I don’t know where the file located to remove this lines forever
hmmm maybe with css?
ever find a solution to this?
nope, not possible yet
Hi All
I saw others doing the following:
In the configuration.yaml
camera:
- platform: generic
name: "XXX Meteogram"
still_image_url: https://www.yr.no/place/xxx/xxx/advanced_meteogram.svg
content_type: 'image/svg+xml'
And then this in lovelace config
entity: camera.rivonia_meteogram
show_name: false
show_state: false
type: picture-entity
Works great for me
I can confirm
show_name: false
show_state: false
on lovelace config does the trick
