Hide custom card based on dates
Is there a way to hide a card based on dates? I have the following:
but I would like to hide it during the winter months since the sensor is inside the house, and not in the water.
Suggestions?
Thanks!
You can set the visible attribute for the group using a template. Build a template that returns True or False depending on now()
https://home-assistant.io/docs/configuration/group_visibility/
Ah… Great, thanks. I will try that…
