I’ve looked thru the documentation and can’t figure this out. Anyone know a way to hide the “night mode” setting when using the Envisalink integration?
Wife set off the alarm this morning letting the dog out and I am now urgently searching for a solution
The mode suddenly showing on the new card. She hit the wrong one…
Ive got a similar setup, my wife complained about the same thing a couple weeks ago. She didn’t set it off. I have this on my list to look at. I’ll take a look today…
The envisalink integration does not have an option to disable one of the discovered states of the panel. (Probably where this belongs.) Th e integration also needs some other love as you may have already noticed it’s entities do not have unique_id’s This is probably a feature request.
Why:
Your workaround is to use either the alarm control panel card or the mushroom card in the UI - Both have controls to disable certain states as I’ve done here. (Mine is a DSC PowersSeries 16xx and supports Night just like yours - note how I’ve filtered it out of the UI here:)
There’s simply no controls to alter the behavior of the system dialog. I suspect the author would refer you to ‘whatever the integration supports’ and therefore placing the onus on allowing customization to the envisalink integration.
So your workaround is to explain the situation and place a customized copy of one of the controls on your UI to prevent it as mentioned above and/or open a bug / feature request against the envisalink integration here:
