I have two sensors wich I would like to hide based on my zone “home”.
api_key: **********
origin: device_tracker.iphone-a
destination: zone.home
- platform: google_travel_time
api_key: **********
origin: device_tracker.iphone-b
destination: zone.home```
So if the tracker finds these iphone's in the "home" zone, I would no longer want to display these.
I habe been unable to find the solution anywhere.
Thanks,
Michel
It sounds like you can achieve this using automations based on the state of the device ‘home’ or if the device enters the zone and the group visibility service .
Maybe I should post some configs to clarify things:
I have a tracker for 2 iphone’s:
device_tracker.iphonevanmichel
and device_tracker.iphonevanlinda
I have multiple zone’s, but the home zone is simply zone.home.
I have 2 sensors:
# Tracking Michel to zone.home
name: Michel naar huis
api_key: ****************************************************
origin: device_tracker.iphonevanmichel
# Tracking Linda to zone.home
name: Linda naar huis
origin: device_tracker.iphonevanlinda
In the most ideal situation I would like to hide any of the 2 sensors in the group when they are in zone.home (or if the travel time = 0)
Since they obviously would not always be home at the same time, I eihter want to hide the respective sensor only. If that is not possible I will create 2 seperate groups.
For now I am not even able to hide the entire group if one of the 2 trackers is home.
