High accuracy mode notification
Hi there,
Just wanted to ask about the geocoded location in the high accuracy mode notification. While driving, it updates correctly with the correct address.
The data in sensor.myphone_geocoded_location isn’t in sync with the notification. Is it possible to pass the notification data to a sensor to have more frequent updates than what we currently have?
Did you change the update frequency? You can set it in seconds.
Yes, set at 5 seconds. The notification shows the location correctly.
I was asking if the sensor.myphone_location_background is available in HA?
Location sensors are only used for the device tracker.
Thanks for clarifying!
