I have high accuracy in the expanded home zone turned on. It mostly works as expected, however:
Sometimes it also turns on (with notification) while home. My trackers show me as home. Turning the high accuracy off and on again just brings it back up.
What am I doing wrong?
Check the logs under App Configuration when this happens to see the cause of it being enabled. You may need to adjust accuracy settings if the geofence see’s you outside the zone when you are at home.
01-20 15:01:59.213 13290 13425 D LocBroadcastReceiver: High accuracy mode enabled, because in zone [zone.home_expanded]
Is the reason. However, my gps tracker shows me as home. Accuracy seems ok. I’m going to fiddle with it to test.
After changing the accuracy multiple times, and changing the home radius too… It keeps happening. There’s nothing in the log that indicates why it’s happening. Nothing besides what I already posted.
Anyone else with this problem?
Edit to add logs:
04-17 13:08:38.786 23208 23208 D LocBroadcastReceiver: Received location update.
04-17 13:08:38.794 23208 23208 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = true
04-17 13:08:38.800 23208 23208 D LocBroadcastReceiver: Last Location:
04-17 13:08:38.800 23208 23208 D LocBroadcastReceiver: Coords:(*****coords are in my home zone*****)
04-17 13:08:38.800 23208 23208 D LocBroadcastReceiver: Accuracy: 11.476
04-17 13:08:38.800 23208 23208 D LocBroadcastReceiver: Bearing: 248.34637
04-17 13:08:38.819 23208 23208 D LocBroadcastReceiver: High accuracy mode enabled, because in zone [zone.home_expanded]
04-17 13:08:38.819 23208 23208 D LocBroadcastReceiver: Begin evaluating if location update should be skipped
04-17 13:08:38.819 23208 23208 D LocBroadcastReceiver: Received location that is 125 milliseconds old, 1650193718694 compared to 1650193718819 with source fused
04-17 13:08:38.821 23208 23355 D UrlRepository: localUrl is: true and usesInternalSsid is: true
04-17 13:08:38.851 23208 23355 D LocBroadcastReceiver: Location update sent successfully
04-17 13:08:44.089 23208 23208 D LocBroadcastReceiver: Received location update.
04-17 13:08:44.094 23208 23208 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = true
04-17 13:08:44.096 23208 23208 D LocBroadcastReceiver: Last Location:
04-17 13:08:44.096 23208 23208 D LocBroadcastReceiver: Coords:(******in my home zone******)
Can you share a screenshot of how you setup the expanded zone in the app settings?
I know the radius is huge. I need it for accuracy close to home.
