High battery consumption in flight mode and without WiFi
Hello this is my first post here on the forum. Sorry for my bad English. I am from Germany.
I have been using Home Assistant for almost a year now. Mainly because of the Companion App. That was the reason why I switched from IO Broker.
Now to my problem.
Since the last update of the Android Companion App (version 2023.3.0-full), I have extremely high battery consumption on 3 Android phones.
My husband has not activated the automatic updates in the Play Store and therefore still has version 2023.1.1-full. He does not have the problem.
The settings in the app are the same on all 4 phones. We haven’t changed anything in the settings on the 3 phones with the new version either.
We only use the app at home in the WLAN. My Rasperry Pi has no internet connection (I’m a bit paranoid :slight_smile:
Accordingly, I have set the permanent connection in the app to “Always”.
I have deactivated all location sensors. Only the battery status is transmitted.
However, I have not changed this setting to the previous version. They were always like this.
With the 3 mobile phones with the latest version of the app, we have more than 25% battery loss overnight in the mobile phone’s flight mode. The same happens when we are not in the Wi-Fi area of the house. Then the battery consumption increases very strongly.
At home in the Wi-Fi area, everything is fine if the mobile phone has Wi-Fi reception.
During a normal working week when I’m not at home, the Home Assistant app takes up more than 50% of the total battery consumption. It’s the same with my children. It wasn’t like this on all three phones before the app update.
I have also uninstalled and reinstalled the app. No success. Still the same problem.
At the moment, I force the app to stop when I drive to work or set the mobile phone to flight mode in the evening. I have uninstalled the app on my children’s phones at the moment. But I don’t want this to be permanent.
I have already seen this page.
Does no one else have this problem? Does anyone have any ideas what else I can try?
Thank you for reading.
Greetings Monika
Hi Monica,
I am having what appears to be a similar issue to you. I had 75% battery, put my phone in airplane mode, went to sleep for 9 hours, and then woke up with it at 14% battery. The built-in battery usage showed Home Assistant consumed 47%.
I rebooted my phone and will see if I can replicate the issue. Sorry I can’t be of more help, but I wanted to share that I had this issue too.
My phone is an Android Pixel 4a with LineageOS 20-20230219-micrG-sunfish. Home Assistant app is version 2023.3.0-full from the Aurora Store.
(Your English is flawless, by the way.)
weve had an issue reported recently
developers have not had much luck reproducing or knowing where the issue comes from.
Are both of you guys using the persistent connection set to always ?
Similar thing happening on my phone and my wife’s - both android and started in the last week or two both on v2023.3.0 . We get massive battery drain and is to the point where whatever the problem is, is draining the battery on my phone as fast as charging it.
I notice in the logs Bluetooth problems, which may make sense as the beacon monitor was part of the
05-03 18:02:15.025 17251 17320 D BluetoothAdapter: isLeEnabled(): ON
05-03 18:02:15.025 17251 17320 D BluetoothLeScanner: could not find callback wrapper
05-03 18:02:16.233 17251 17320 D BluetoothAdapter: isLeEnabled(): ON
05-03 18:02:16.233 17251 17320 D BluetoothLeScanner: could not find callback wrapper
05-03 18:02:17.822 17251 17320 D
05-03 18:02:17.822 17251 17320 D BluetoothLeScanner: could not find callback wrapper
05-03 18:02:19.421 17251 17320 D BluetoothAdapter: isLeEnabled(): ON
05-03 18:02:19.421 17251 17320 D BluetoothLeScanner: could not find callback wrapper
05-03 18:02:20.522 17251 17320 D BluetoothAdapter: isLeEnabled(): ON
05-03 18:02:20.523 17251 17320 D BluetoothLeScanner: could not find callback wrapper
05-03 18:02:20.636 17251 17251 D LocBroadcastReceiver: Received location update.
05-03 18:02:20.638 17251 17251 W LocBroadcastReceiver: Location accuracy didn’t meet requirements, disregarding: Location[fused xxxxxccc,xxxxxx hAcc=252.5 et=+21d8h34m17s659ms alt=61.70000076293945 vAcc=1.0991334 vel=0.05099606 sAcc=3.0513768]
05-03 18:02:21.020 17251 17320 D BluetoothAdapter: isLeEnabled(): ON
05-03 18:02:21.020 17251 17320 D BluetoothLeScanner: could not find callback wrapper
05-03 18:02:23.022 17251 17251 E CycledLeScannerForLollipop: Scan failed: app cannot be registered
05-03 18:02:23.023 17251 17320 D BluetoothAdapter: isLeEnabled(): ON
05-03 18:02:23.023 17251 17320 D BluetoothLeScanner: could not find callback wrapper
05-03 18:02:24.221 17251 17320 D BluetoothAdapter: isLeEnabled(): ON
05-03 18:02:24.221 17251 17320 D BluetoothLeScanner: could not find callback wrapper
05-03 18:02:25.821 17251 17320 D BluetoothAdapter: isLeEnabled(): ON
05-03 18:02:25.821 17251 17320 D BluetoothLeScanner: could not find callback wrapper
05-03 18:02:27.422 17251 17320 D BluetoothAdapter: isLeEnabled(): ON
05-03 18:02:27.422 17251 17320 D BluetoothLeScanner: could not find callback wrapper
05-03 18:02:28.530 17251 17320 D BluetoothAdapter: isLeEnabled(): ON
05-03 18:02:28.530 17251 17320 D BluetoothLeScanner: could not find callback wrapper
And on and on and on.
I have turned off Bluetooth on my phone and will see what happens.
This looks like you had either the Bluetooth transmitter or beacon monitor enabled. Both of those drain battery.
have a similar or the same problem. The massive loss of battery power only occurs sporadically. 1 in 3 to 4 days. The HA app version is 2023.3.-full. Bluetooth is permanently on (Smartphone). At night, the smartphone is always on “Do not disturb” and “Flight mode”. Android 13 is running on it.
Frank
My persistent connection was set to Never. I found this setting through your other post - thanks!
Hello and thank you for the feedback so far. I am now reassured that this is not my problem alone. Unfortunately, my husband has now also made the update by mistake :roll_eyes:. The next morning, the same problem. So now I have 4 mobile phones with the same problem. For us, the permanent connection is set to always, as I don’t allow my Rasperry Pi to access the Internet.
I force the app to stop every evening. Then my battery is not empty.
I hope that a cause and solution will be found there.
Have a nice evening… Monika
for me an uninstall of the app from my smartphone and the follow up new installation solved the problem.
Frank
