High CPU load for 20mins under 0.48 and 0.49
I experienced this once under 0.48, but I was trying out gstreamer which introduced similar problems on its own. So I dropped back to an sd image with just 0.47 on it, and everything worked fine for several days, but after upgrading to 0.49 yesterday morning I got another period of high cpu at 19:40 GMT, that lasted for about 20 minutes.
There is nothing useful in the HA log, except that it was taking a long time time to do things
2017-07-25 19:21:39 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-25 19:24:37 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-25 19:24:41 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-25 19:24:47 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-25 19:27:26 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-25 19:39:56 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:01:00
2017-07-25 19:39:56 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating workday binary_sensor took longer than the scheduled update interval 0:00:30
2017-07-25 19:39:56 WARNING (MainThread) [homeassistant.components.sensor] Updating darksky sensor took longer than the scheduled update interval 0:00:30
2017-07-25 19:39:56 WARNING (MainThread) [homeassistant.components.sensor] Updating systemmonitor sensor took longer than the scheduled update interval 0:00:30
2017-07-25 19:39:56 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-25 19:39:56 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.mosquitto_status is taking over 10 seconds
2017-07-25 19:39:56 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.dark_sky_cloud_coverage is taking over 10 seconds
2017-07-25 19:40:14 WARNING (MainThread) [homeassistant.core] Unable to remove unknown listener <function async_track_point_in_utc_time.<locals>.point_in_time_listener at 0xae651348>
2017-07-25 19:40:21 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ping binary_sensor took longer than the scheduled update interval 0:05:00
2017-07-25 19:40:21 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:01:00
2017-07-25 19:40:21 WARNING (MainThread) [homeassistant.components.sensor] Updating darksky sensor took longer than the scheduled update interval 0:00:30
2017-07-25 19:40:21 WARNING (MainThread) [homeassistant.components.sensor] Updating systemmonitor sensor took longer than the scheduled update interval 0:00:30
2017-07-25 19:40:23 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-25 19:40:23 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.naospc is taking over 10 seconds
2017-07-25 19:40:23 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.appdaemon_status is taking over 10 seconds
2017-07-25 19:40:23 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.dark_sky_precip_probability is taking over 10 seconds
2017-07-25 19:40:26 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-25 19:40:29 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-25 19:40:31 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-25 19:40:31 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.open_files is taking over 10 seconds
2017-07-25 20:26:53 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.dark_sky_cloud_coverage is taking over 10 seconds
2017-07-25 21:53:47 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-26 06:31:25 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-26 06:31:42 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.dark_sky_cloud_coverage is taking over 10 seconds
2017-07-26 07:37:10 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-26 07:37:22 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-26 08:11:53 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-26 08:11:59 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-26 08:12:40 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-26 08:13:35 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-07-26 08:13:36 WARNING (MainThread) [homeassistant.components.sensor] Updating darksky sensor took longer than the scheduled update interval 0:00:30
2017-07-26 08:13:36 WARNING (MainThread) [homeassistant.components.sensor] Updating systemmonitor sensor took longer than the scheduled update interval 0:00:clock1030:
The only extra thing in /var/log/syslog is this, at the end of the period
Jul 25 19:40:14 raspberrypi hass[2325]: WARNING:homeassistant.core:Unable to remove unknown listener <function async_track_point_in_utc_time.<locals>.point_in_time_listener at 0xae651348>
Has anyone experienced something similar, or have any insights as to what is happening?
This also seems to correlate with something eating up some memory, which was released when I restarted HA
After adding a bit more logging, I have discovered that this coincides with a large number of MQTT messages coming from my light sensor around dusk. It seems that the later versions of HA have a hard time handling this.
Adding some debounce code to the light sensor sketch just moved up my priority list.
hi,
not wanting to bump this unnecessarily but you’re just about the only one posting about the Unable to remove unknown listener i am experiencing also lately.
I also have a rather extensive mqtt setup, so was keen to know if you ever managed to resolve this? If so, how? Especially interested in your ;debounce code’…
cheers,
Marius
The problem was the light sensor sending too many MQTT messages at once. I just made sure that a maximum of one message is sent every second. I can look it up if you need, but there isn’t much to it.
please if you have spare moment, let me know what you did. I just might need such a simple thing.
Maybe this coincides with some other issues, web sockets, max messages, etc i see every now and then.
Cheers,
Marius
This is my light sensor sending code. I’m really not sure how it will help you though.
  if (mqttClient.connected()) {
    //Light level
    // Only send once a second to avoid spamming when light
    // level is on the limit
    if (now < lastDarkMessage // Check for wrap around
        now > (lastDarkMessage + 1000)
        || firsttime == true) {
      boolean currentLight = (digitalRead(LIGHT_LEVEL_PIN) == HIGH);
      if (lightlevel && !currentLight) {
        sendMQTT("sensor/433/dark", "OFF", false);
        lightlevel = currentLight;
        lastDarkMessage = now;
      } else if (!lightlevel && currentLight) {
        sendMQTT("sensor/433/dark", "ON", false);
      } else if (firsttime == true) {
        sendMQTT("sensor/433/dark", currentLight?"ON":"OFF", false);
