I’ve a running installation of HASS OS in a VM on a NUC. The ethernet adapter is in bridged mode. I have multiple VLANs with mDNS enabled on my Unifi Security Gateway.
I see a high CPU load on systemd-resolved (about every half a minute). When I enable debug in the logging, the logs are flooded with the messages below (150MB in a couple of minutes). Does anyone have an idea about what could be causing this?
core-2021.6.0 (seen on 5.x as well)
Home Assistant OS 5.13
2021-06-04 09:16:12 DEBUG (zeroconf-Engine-248) [zeroconf] Ignoring duplicate message received from '192.168.2.67':5353 (socket 30) (137 bytes) as [b'\x00\x00\x84\x00\x00\x00\x00\x02\x00\x00\x00\x003homeassistant649 [0e1259a0de274c3a94c95a35f4b893c9]\x0c_workstation\x04_tcp\x05local\x00\x00\x10\x80\x01\x00\x00\x00x\x00\x01\x00\xc0\x0c\x00!\x80\x01\x00\x00\x00x\x00\x19\x00\x00\x00\x00\x00\x00\x10homeassistant649\xc0R']
2021-06-04 09:16:12 DEBUG (zeroconf-Engine-248) [zeroconf] Ignoring duplicate message received from '172.30.32.1':5353 (socket 30) (137 bytes) as [b'\x00\x00\x84\x00\x00\x00\x00\x02\x00\x00\x00\x003homeassistant649 [0e1259a0de274c3a94c95a35f4b893c9]\x0c_workstation\x04_tcp\x05local\x00\x00\x10\x80\x01\x00\x00\x00x\x00\x01\x00\xc0\x0c\x00!\x80\x01\x00\x00\x00x\x00\x19\x00\x00\x00\x00\x00\x00\x10homeassistant649\xc0R']
2021-06-04 09:16:12 DEBUG (zeroconf-Engine-248) [zeroconf] Ignoring duplicate message received from '192.168.30.1':5353 (socket 30) (137 bytes) as [b'\x00\x00\x84\x00\x00\x00\x00\x02\x00\x00\x00\x003homeassistant649 [0e1259a0de274c3a94c95a35f4b893c9]\x0c_workstation\x04_tcp\x05local\x00\x00\x10\x80\x01\x00\x00\x00x\x00\x01\x00\xc0\x0c\x00!\x80\x01\x00\x00\x00x\x00\x19\x00\x00\x00\x00\x00\x00\x10homeassistant649\xc0R']
2021-06-04 09:16:12 DEBUG (zeroconf-Engine-248) [zeroconf] Ignoring duplicate message received from '192.168.50.1':5353 (socket 30) (137 bytes) as [b'\x00\x00\x84\x00\x00\x00\x00\x02\x00\x00\x00\x003homeassistant649 [0e1259a0de274c3a94c95a35f4b893c9]\x0c_workstation\x04_tcp\x05local\x00\x00\x10\x80\x01\x00\x00\x00x\x00\x01\x00\xc0\x0c\x00!\x80\x01\x00\x00\x00x\x00\x19\x00\x00\x00\x00\x00\x00\x10homeassistant649\xc0R']
2021-06-04 09:16:12 DEBUG (zeroconf-Engine-248) [zeroconf] Received from '192.168.2.67':5353 (socket 30): <DNSIncoming:{id=0, flags=0, n_q=2, n_ans=0, n_auth=3, n_add=0, questions=[question[any,in,homeassistant651 [0e1259a0de274c3a94c95a35f4b893c9]._workstation._tcp.local.], question[any,in,homeassistant651.local.]], answers=[record[txt,in-unique,homeassistant651 [0e1259a0de274c3a94c95a35f4b893c9]._workstation._tcp.local.]=120/119,b'\x00', record[srv,in-unique,homeassistant651 [0e1259a0de274c3a94c95a35f4b893c9]._workstation._tcp.local.]=120/119,homeassistant651.local.:0, record[a,in-unique,homeassistant651.local.]=120/119,192.168.2.67]}> (187 bytes) as [b'\x00\x00\x00\x00\x00\x02\x00\x00\x00\x03\x00\x003homeassistant651 [0e1259a0de274c3a94c95a35f4b893c9]\x0c_workstation\x04_tcp\x05local\x00\x00\xff\x00\x01\x10homeassistant651\xc0R\x00\xff\x00\x01\xc0\x0c\x00\x10\x80\x01\x00\x00\x00x\x00\x01\x00\xc0\x0c\x00!\x80\x01\x00\x00\x00x\x00\x1e\x00\x00\x00\x00\x00\x00\x10homeassistant651\x05local\x00\xc0]\x00\x01\x80\x01\x00\x00\x00x\x00\x04\xc0\xa8\x02C']
2021-06-04 09:16:12 DEBUG (zeroconf-Engine-248) [zeroconf] Received from '192.168.40.1':5353 (socket 30): <DNSIncoming:{id=0, flags=0, n_q=2, n_ans=0, n_auth=0, n_add=0, questions=[question[any,in,homeassistant651 [0e1259a0de274c3a94c95a35f4b893c9]._workstation._tcp.local.], question[any,in,homeassistant651.local.]], answers=[]}> (116 bytes) as [b'\x00\x00\x00\x00\x00\x02\x00\x00\x00\x00\x00\x003homeassistant651 [0e1259a0de274c3a94c95a35f4b893c9]\x0c_workstation\x04_tcp\x05local\x00\x00\xff\x00\x01\x10homeassistant651\xc0R\x00\xff\x00\x01']
2021-06-04 09:16:12 DEBUG (zeroconf-Engine-248) [zeroconf] Ignoring duplicate message received from '192.168.2.67':5353 (socket 30) (116 bytes) as [b'\x00\x00\x00\x00\x00\x02\x00\x00\x00\x00\x00\x003homeassistant651 [0e1259a0de274c3a94c95a35f4b893c9]\x0c_workstation\x04_tcp\x05local\x00\x00\xff\x00\x01\x10homeassistant651\xc0R\x00\xff\x00\x01']
2021-06-04 09:16:12 DEBUG (zeroconf-Engine-248) [zeroconf] Ignoring duplicate message received from '172.30.32.1':5353 (socket 30) (116 bytes) as [b'\x00\x00\x00\x00\x00\x02\x00\x00\x00\x00\x00\x003homeassistant651 [0e1259a0de274c3a94c95a35f4b893c9]\x0c_workstation\x04_tcp\x05local\x00\x00\xff\x00\x01\x10homeassistant651\xc0R\x00\xff\x00\x01']
2021-06-04 09:16:12 DEBUG (zeroconf-Engine-248) [zeroconf] Received from '192.168.2.67':5353 (socket 30): <DNSIncoming:{id=0, flags=32768, n_q=0, n_ans=3, n_auth=0, n_add=0, questions=[], answers=[record[txt,in-unique,homeassistant651 [0e1259a0de274c3a94c95a35f4b893c9]._workstation._tcp.local.]=120/119,b'\x00', record[srv,in-unique,homeassistant651 [0e1259a0de274c3a94c95a35f4b893c9]._workstation._tcp.local.]=120/119,homeassistant651.local.:0, record[a,in-unique,homeassistant651.local.]=120/119,192.168.2.67]}> (175 bytes) as [b'\x00\x00\x80\x00\x00\x00\x00\x03\x00\x00\x00\x003homeassistant651 [0e1259a0de274c3a94c95a35f4b893c9]\x0c_workstation\x04_tcp\x05local\x00\x00\x10\x80\x01\x00\x00\x00x\x00\x01\x00\xc0\x0c\x00!\x80\x01\x00\x00\x00x\x00\x1e\x00\x00\x00\x00\x00\x00\x10homeassistant651\x05local\x00\x10homeassistant651\xc0R\x00\x01\x80\x01\x00\x00\x00x\x00\x04\xc0\xa8\x02C']
