as anticipated in the topic I’m struggling to high CPU on HOST usage after update. I thought it was due to DB update but is constant and (it seems) that only solution is downgrade.
This is my version:
Home Assistant
Core 2024.8.2
Frontend 20240809.0
Running in Proxmox Virtual Environment 8.2.4 as VM
Same here. I’ve installed the update today coming from 7.x to 8.3. Now my fan is running permanently and the cpu usage is at 80+ percent. I’m using a NUC.
Edit: it’s back to normal now. Seems like that db migration took longer than I expected.
