High CPU usage - need advice/help
My HA, is running on a I5-6500, SSD drive, and 8 GB ram, but my CPU load is between 10 and 25 pct. it that normal ? and can someone help me debug why the CPU load is that high ??
I have tried the profiler, and have data from a 5 min periode, but must admit, I do not understand the output…
I hope someone might help me …
It depends what type of instalation are you using how many addons are you using. Do you have frigate cameras, how many devices services etc.
Yea, just think it high, no frigate. Some Reolink cam’s only using the Reolink built-in AI
Z-wave and Zigbee, and some wifi devices…
Automations 68
Binary sensors 236
Custom integrations 23
Devices 362
Entities 2.238
Integrations 108
My average cpu load is around 19 % on i3. I have frigate and doorbell camera. I have around 100 devices, mostly zigbee integrated in ha. If using docker standalone installation there is a good integration - docker monitor.With this you can see how much resources is used by every container. Frigate and code server are two containers aka addons that uses the most resources.
I don’t think that you have high cpu usage. Maybe you can optimize it, but it might depend on your installation type.
