An idea! Should there be more than one SyncWorker_n thread for any value of n? It would seem that there should be only 1 SyncWorker_6 thread, for example. When I get threads that are fully utilizing a cpu core they always have the same “n” following SyncWorker_.
I’m not sure where/when those are created.
It’s very odd! I can see where the SyncWorker threads get created as part of Threading. Later, one of the SyncWorker threads seems to get copied … but only sometimes.
I have no idea if it is within HA or some other part of python.
Update: I had it happen again with the thread being ImportExecutor. My best guess is it happens sometime between starting the Recorder thread and the DbWorker threads.
All seems fine up through the Recorder thread initializing
A thread shows up in ps named “Thread-2 (_run_safe_shutdown_loop)” - this might be before or after the cloning – I’m confirming relative timing.
Before DbWorker threads are created, one of the previously created threads appears to be “cloned” – could be SyncWorker_n or ImportExecutor. These threads are not created by threading.Thread like other threads in HA.
The “clones” of the thread consume ~100% of a cpu core. The original of the thread seems to operate as normal.
The number of clones created is related to the number of cores I let HA use. It is number of cores - 1.
So I think I have solved my problem by restricting HA to run on only 1 core. My setup is so simple that this is more than enough CPU.
I tested all of this on a different Android device, running a Android 11 (my main device is Android 7) and the behavior is the same.
I can try to figure out what is happening between the Recorder thread and the DbWorker thread that might be causing this “cloning” but since I have no prior knowledge of the system, that feels like a complicated fishing expedition. Maybe I’ll try that in a month or two if I have more time.
