ChoiZ
1
I use HASS.io on my NAS server (4 CPU) and sometimes the docker container with homeassistant takes 25% of CPU (so 100% of 1/4 CPU)
I’ve try to restart the docker, remove useless sensors, remove many things but I can’t avoid that.
When I listen music with MPD on the NAS the music cut because of this issue.
I don’t want to migrate my homeassistant on a raspberry pi so I want to have a solution for that.
I use:
- Adguard
- HACS
- ESPHome
- Zigbee2MQTT
- Anniversaries
- home-assistant-variables
- Sonoff LAN
I use the last home-assistant update (0.108.9) but the issue is since 108 maybe.
I have disabled my “brother” printer and all configuration about brother because I read issues on it.
- How to rollback on the last 0.107 with hass.io?
sender
2
Do you have glances as an addon?
To roll back to an older install I have used the ‘SSH & Web Terminal’ add on with the command:
ha core update --version=0.107.7
Had a similar issue on my RPi3 starting with V0.108.0 but it fixed itself, kind of, with V0.108.8
ChoiZ
4
Do you mean glance in the UI like that?
entities:
- entity: light.living_room
tap_action:
action: toggle
- entity: light.led_tv
tap_action:
action: toggle
- entity: light.led_mirror
tap_action:
action: toggle
title: Salon
type: glance
ChoiZ
5
You’re lucky
Thanks for the command to rollback to 0.107.7 I’ll try that.
ChoiZ
6
Thanks for the command, I’m now back on 0.107.7 I’ll check tomorrow morning how it was with this version.
ChoiZ
7
I’ve done the rollback on 0.107.7 at 22:38.
So I’ve got one cpu pick few minutes later.
I’ll post later…
bdraco
(J. Nick Koston)
8
Try to get a recording with py-spy
https://github.com/benfred/py-spy
sender
9
I meant the addon glance. I have issue with cpu with that. If i stop and start after a hassos reboot its gone.
ChoiZ
10
Nope I haven’t this addon
ChoiZ
11
ChoiZ
12
My home-assistant_v2.db size is 31G…
the home-assistant_v2.db-shm size is 5.1M
the home-assistant_v2.db-wal size is 2,6G
Is it normal? How I can purge the database without loosing my config?
ChoiZ
13
I have execute a:
recorder.purge
keep_days: 7
repack: true
bdraco
(J. Nick Koston)
14
Nothing looks out of the ordinary with the py-spy
recording. Was the cpu spiking when the recording took place?
It would be helpful to see what is generating all the states and events in the database. Please check: Large homeassistant database files
ChoiZ
15
I have remove my database now it’s about 1,6Mo
So I still have the issue
I launch py-spy recording at 13:14 (last 2 peaks but not reach 25% of cpu).
Here the result: https://www.choiz.fr/images/profile_homeassistant.svg
bdraco
(J. Nick Koston)
16
Its going to be near impossible to figure out what is going on unless you can get a capture when the issue is happening.
ChoiZ
17
Yes I know
I try to capture when it happened but it’s difficult because it’s very random…
