I recently setup a Synology DS918+ with HASS in a docker image and I’m experiencing high I/O wait due to high disk writes
I’ve disabled both history and recorder and have my logging set as
logger:
default: error
I’m using influxdb but I still experience high disk writes with it disabled.
If I strip out everything, the high I/O wait is gone but as soon as I revert back to my full config, it shoots back up.
Other than adding each item back to the config one by one, is there a way to figure out how each component affects the disk writes?
thanks
