High Load and CPU -> reduce debug logging = christmas gift
Hello
I was woundering why my load and cpu is higher than usual. Then I saw, that my general logger was on “debug”. I have forgotten so set back. So Home Assistant has written a lot of stuff to the log file.
In my case reduce the logging from debug to info, reduced the CPU and load to the half value. I have running a Pi4.
So my tip: please check your logging, maybe you have forgotten so set it back.
I dont want to start a discussion about logging. It is totaly correct that the logger in debug mode logs so much information. It is just a reminder to others, to check your logger configuration.
