High mem/cpu use of Core HA
Last 2 weeks I have been running into this odd issue, running HA OS on an intel nuc type of mini PC and I have seen CPU jump to 60-100% for no apparent reason and a restart will fix it.
Not seeing anything in the logs, but Core cpu usage under the supervisor blade, this seems to be the issue.
Problem is I have no idea what is actually causing the spike.
How can I find if a process is running amok and what one is doing it?
Hi sd_dracula,
An add-on running will do that, what add-ons do you have?
That’s what I thought but when I checked each of them I could not see any being higher than normal:
Any command I could run on the cmd line that lists all processes and their mem/cpu consumption?
