High Memory Usage for hass
Today i noticed slow response on Home Assistant, i cannot figure out any issues, and after restart the usages recovers (looks like a memory leak) it seems fine
After restart the RAM usage returns to 3%
I`m running Home Assistant 2021.12.10 and did not do any big changes like new plugins or stuff
This is memory graph
This is the CPU graph
Today the problem reoccurred and i stil did no find an answer
top - 21:32:13 up 18 days,  1:30,  2 users,  load average: 1.65, 2.20, 2.20
Tasks: 164 total,   1 running, 163 sleeping,   0 stopped,   0 zombie
%Cpu(s):  4.5 us,  1.2 sy,  0.0 ni, 91.6 id,  2.4 wa,  0.0 hi,  0.3 si,  0.0 st
MiB Mem :   7700.2 total,   3483.0 free,   1424.5 used,   2792.7 buff/cache
MiB Swap:   4096.0 total,   2307.7 free,   1788.3 used.   5960.2 avail Mem
    PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
1198069 homeass+  20   0 1707196 250604  34844 S   6.3   3.2   1:19.35 hass
1245333 dsmr      20   0   86512  68112  17248 S   2.7   0.9   0:01.27 python3
1245335 postgres  20   0  250236  16172  14388 S   1.0   0.2   0:00.08 postgres
1198948 dsmr      20   0   86900  68344  17244 S   0.7   0.9   0:08.40 python3
    737 root      20   0   81828   2928   2856 S   0.3   0.0   1:22.39 irqbalance
 524363 homeass+  20   0  410884  27068   5724 S   0.3   0.3  17:55.39 nx584_server
1198179 raymon    20   0   14048   5452   3960 S   0.3   0.1   0:00.15 sshd
1198950 postgres  20   0  250260  20920  18688 S   0.3   0.3   0:02.55 postgres
1199272 root      20   0       0      0      0 I   0.3   0.0   0:00.65 kworker/0:3-events
1245230 root      20   0    9548   4232   3508 R   0.3   0.1   0:00.31 top
      1 root      20   0  171048  11380   6524 S   0.0   0.1   1:33.25 systemd
      2 root      20   0       0      0      0 S   0.0   0.0   0:00.59 kthreadd
However i did upgrade from homeassistant 2021.12.10 to homeassistant-2022.2.6
How do you get this screen?
htop on the commandline (ssh)
The issue still seems to hit me from time to time
root@knopjes01:/home/raymon# top
top - 10:25:05 up 3 days, 13:00,  2 users,  load average: 0.14, 0.18, 0.18
Tasks: 163 total,   1 running, 162 sleeping,   0 stopped,   0 zombie
%Cpu(s):  1.9 us,  0.5 sy,  0.0 ni, 97.5 id,  0.0 wa,  0.0 hi,  0.1 si,  0.0 st
MiB Mem :   7867.2 total,    130.3 free,   5902.4 used,   1834.6 buff/cache
MiB Swap:   4096.0 total,   3996.2 free,     99.8 used.   1607.7 avail Mem
  72328 homeass+  20   0 7037916   3.9g  40240 S   5.7  50.7 230:45.66 hass
  31492 homeass+  20   0  974384 146552  31176 S   1.3   1.8  66:15.17 zwavejs+
  71440 dsmr      20   0  125520  92156  14912 S   1.0   1.1  40:50.70 python3
    422 root      19  -1  200084 143240 141756 S   0.3   1.8   6:35.80 systemd+
  63289 Debian-+  20   0   22228  12528   7900 S   0.3   0.2   2:07.21 snmpd
 130890 postgres  20   0  217744  29968  26392 S   0.3   0.4   0:08.24 postgres
 131525 root      20   0    7920   3784   3180 R   0.3   0.0   0:00.01 top
      1 root      20   0  167728  12868   7932 S   0.0   0.2   0:09.72 systemd
I`m not sure what is causing this, it was fine for some time, but then some days with high mem load, which eventually hangs the machine after swapping itself to death. The machine has 8GB ram which should be more than enough
Home Assistant 2022.8.6
Frontend 20220802.0 - latest
I`m still having this issue, from time to time HASS eats up all the memory and it is killed by oom-killer or swaps the system till death
top - 23:59:01 up 5 days, 10:01,  2 users,  load average: 0.17, 0.24, 0.19
Tasks: 166 total,   3 running, 163 sleeping,   0 stopped,   0 zombie
%Cpu(s):  4.4 us,  0.7 sy,  0.0 ni, 94.3 id,  0.2 wa,  0.0 hi,  0.4 si,  0.0 st
MiB Mem :   7867.2 total,    121.6 free,   6577.3 used,   1168.3 buff/cache
MiB Swap:   4096.0 total,   2837.0 free,   1259.0 used.    928.0 avail Mem
 137095 homeass+  20   0 8138344   5.0g  36316 S  10.0  65.0 289:47.20 hass
    775 homeass+  20   0  965168 117640  19948 S   4.0   1.5 132:12.40 zwavejs2mqtt
 136829 dsmr      20   0  125532  81764   9932 R   2.3   1.0  55:01.91 python3
 170867 dsmr      20   0  125760  94400  16636 S   1.7   1.2  18:51.49 python3
    438 root      19  -1  171248  91320  90236 S   0.7   1.1  10:36.26 systemd-journal
 143909 homeass+  20   0  964872 106772  24528 S   0.7   1.3   1:04.04 node
 226284 postgres  20   0  217528  19344  17012 S   0.7   0.2   0:01.09 postgres
 226427 postgres  20   0  217828  20856  18068 R   0.7   0.3   0:00.36 postgres
     28 root      20   0       0      0      0 S   0.3   0.0   0:06.18 ksoftirqd/2
    113 root       0 -20       0      0      0 I   0.3   0.0   0:39.18 kworker/1:1H-kblockd
    760 homeass+  20   0  258092  12636   5520 S   0.3   0.2  10:14.05 nx584_se```
And again issues today
Oct 26 16:11:04 knopjes01 kernel: [612819.027606] intel_powerclamp: Stop forced idle injection
Oct 26 17:23:17 knopjes01 kernel: [617151.826567] intel_powerclamp: Start idle injection to reduce power
Oct 26 17:23:36 knopjes01 kernel: [617170.794366] intel_powerclamp: Stop forced idle injection
Oct 26 17:27:44 knopjes01 kernel: [617418.509024] intel_powerclamp: Start idle injection to reduce power
Oct 26 17:28:08 knopjes01 kernel: [617442.642812] intel_powerclamp: Stop forced idle injection
Oct 26 20:32:16 knopjes01 kernel: [628490.171208] postgres invoked oom-killer: gfp_mask=0x1100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=-900
Oct 26 20:32:16 knopjes01 kernel: [628490.171216] CPU: 3 PID: 897 Comm: postgres Not tainted 5.15.0-52-generic #58-Ubuntu
Oct 26 20:32:16 knopjes01 kernel: [628490.171220] Hardware name: Dell Inc. OptiPlex 3020M/0VRWRC, BIOS A02 11/14/2014
Oct 26 20:32:16 knopjes01 kernel: [628490.171222] Call Trace:
Oct 26 20:32:16 knopjes01 kernel: [628490.171224]  <TASK>
Oct 26 20:32:16 knopjes01 kernel: [628490.171226]  show_stack+0x52/0x5c
Oct 26 20:32:16 knopjes01 kernel: [628490.171232]  dump_stack_lvl+0x4a/0x63
Oct 26 20:32:16 knopjes01 kernel: [628490.171237]  dump_stack+0x10/0x16
Oct 26 20:32:16 knopjes01 kernel: [628490.171240]  dump_header+0x53/0x228
Oct 26 20:32:16 knopjes01 kernel: [628490.171244]  oom_kill_process.cold+0xb/0x10
Oct 26 20:32:16 knopjes01 kernel: [628490.171248]  out_of_memory+0x106/0x2e0
Oct 26 20:32:16 knopjes01 kernel: [628490.171253]  __alloc_pages_slowpath.constprop.0+0x97e/0xa40
Oct 26 20:32:16 knopjes01 kernel: [628490.171259]  __alloc_pages+0x311/0x330
Oct 26 20:32:16 knopjes01 kernel: [628490.171262]  alloc_pages+0x9e/0x1e0
Oct 26 20:32:16 knopjes01 kernel: [628490.171265]  __page_cache_alloc+0x7e/0x90
Oct 26 20:32:16 knopjes01 kernel: [628490.171268]  pagecache_get_page+0x152/0x590
Oct 26 20:32:16 knopjes01 kernel: [628490.171271]  ? page_cache_ra_unbounded+0x166/0x210
Oct 26 20:32:16 knopjes01 kernel: [628490.171275]  filemap_fault+0x488/0xab0
Oct 26 20:32:16 knopjes01 kernel: [628490.171278]  ? filemap_map_pages+0x309/0x400
Oct 26 20:32:16 knopjes01 kernel: [628490.171282]  __do_fault+0x3c/0x120
Oct 26 20:32:16 knopjes01 kernel: [628490.171286]  do_read_fault+0xeb/0x160
Oct 26 20:32:16 knopjes01 kernel: [628490.171290]  do_fault+0xa0/0x2e0
Oct 26 20:32:16 knopjes01 kernel: [628490.171293]  handle_pte_fault+0x1cd/0x240
Oct 26 20:32:16 knopjes01 kernel: [628490.171296]  __handle_mm_fault+0x405/0x6f0
Oct 26 20:32:16 knopjes01 kernel: [628490.171301]  handle_mm_fault+0xd8/0x2c0
Oct 26 20:32:16 knopjes01 kernel: [628490.171304]  do_user_addr_fault+0x1c9/0x670
Oct 26 20:32:16 knopjes01 kernel: [628490.171309]  exc_page_fault+0x77/0x170
Oct 26 20:32:16 knopjes01 kernel: [628490.171314]  asm_exc_page_fault+0x26/0x30
Oct 26 20:32:16 knopjes01 kernel: [628490.171319] RIP: 0033:0x7f7b4e533ec1
Oct 26 20:32:16 knopjes01 kernel: [628490.171322] Code: f1 74 c0 c5 f9 da c1 c5 f9 74 c7 c5 f9 d7 c8 81 e1 ff 00 00 00 85 c9 0f 85 5c ff ff ff 83 c2 08 83 c0 08 3d fc 0f 00 00 7f 28 <c5> f9 6e 0c 17 c5 f9 6e 04 16 c5 f1 74 c0 c5 f9 da c1 c5 f9 74 c7
Oct 26 20:32:16 knopjes01 kernel: [628490.171325] RSP: 002b:00007ffd38118468 EFLAGS: 00010297
Oct 26 20:32:16 knopjes01 kernel: [628490.171329] RAX: 0000000000000ffb RBX: 00007ffd38118500 RCX: 00000000ffffffff
Oct 26 20:32:16 knopjes01 kernel: [628490.171331] RDX: 0000000000000000 RSI: 00007f7b4f0905fb RDI: 00007f7b4f0a8a61
Oct 26 20:32:16 knopjes01 kernel: [628490.171333] RBP: 00007f7b4f0a8a61 R08: 000055901d4fc744 R09: 00000000ffffffff
Oct 26 20:32:16 knopjes01 kernel: [628490.171335] R10: 000055901d4fc753 R11: 0000000000000206 R12: 0000000000000000
Oct 26 20:32:16 knopjes01 kernel: [628490.171337] R13: 000055901d4fc744 R14: 00007f7b4efdc370 R15: 0000000000000000
Oct 26 20:32:16 knopjes01 kernel: [628490.171340]  </TASK>
Oct 26 20:32:16 knopjes01 kernel: [628490.171342] Mem-Info:
Oct 26 20:32:16 knopjes01 kernel: [628490.171343] active_anon:1634453 inactive_anon:295869 isolated_anon:0
Oct 26 20:32:16 knopjes01 kernel: [628490.171343]  active_file:46 inactive_file:137 isolated_file:0
Oct 26 20:32:16 knopjes01 kernel: [628490.171343]  unevictable:6995 dirty:0 writeback:0
Oct 26 20:32:16 knopjes01 kernel: [628490.171343]  slab_reclaimable:12792 slab_unreclaimable:15312
Oct 26 20:32:16 knopjes01 kernel: [628490.171343]  mapped:3460 shmem:15084 pagetables:9145 bounce:0
Oct 26 20:32:16 knopjes01 kernel: [628490.171343]  kernel_misc_reclaimable:0
Oct 26 20:32:16 knopjes01 kernel: [628490.171343]  free:25130 free_pcp:1526 free_cma:0
Oct 26 20:32:16 knopjes01 kernel: [628490.171350] Node 0 active_anon:6537812kB inactive_anon:1183476kB active_file:184kB inactive_file:548kB unevictable:27980kB isolated(anon):0kB isolated(file):0kB mapped:13840kB dirty:0kB writeback:0kB shmem:60336kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 0kB writeback_tmp:0kB kernel_stack:5360kB pagetables:36580kB all_unreclaimable? no
Oct 26 20:32:16 knopjes01 kernel: [628490.171356] Node 0 DMA free:14336kB min:128kB low:160kB high:192kB reserved_highatomic:0KB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15988kB managed:15360kB mlocked:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
Oct 26 20:32:16 knopjes01 kernel: [628490.171362] lowmem_reserve[]: 0 3277 7741 7741 7741
Oct 26 20:32:16 knopjes01 kernel: [628490.171368] Node 0 DMA32 free:45820kB min:28556kB low:35692kB high:42828kB reserved_highatomic:0KB active_anon:2793888kB inactive_anon:606436kB active_file:28kB inactive_file:1256kB unevictable:0kB writepending:0kB present:3571656kB managed:3469420kB mlocked:0kB bounce:0kB free_pcp:2604kB local_pcp:572kB free_cma:0kB
Oct 26 20:32:16 knopjes01 kernel: [628490.171375] lowmem_reserve[]: 0 0 4464 4464 4464
Oct 26 20:32:16 knopjes01 kernel: [628490.171380] Node 0 Normal free:40364kB min:38896kB low:48620kB high:58344kB reserved_highatomic:2048KB active_anon:3743924kB inactive_anon:577040kB active_file:276kB inactive_file:528kB unevictable:27980kB writepending:0kB present:4716544kB managed:4571220kB mlocked:27912kB bounce:0kB free_pcp:3500kB local_pcp:856kB free_cma:0kB
Oct 26 20:32:16 knopjes01 kernel: [628490.171386] lowmem_reserve[]: 0 0 0 0 0
Oct 26 20:32:16 knopjes01 kernel: [628490.171391] Node 0 DMA: 0*4kB 0*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 1*2048kB (M) 3*4096kB (M) = 14336kB
Oct 26 20:32:16 knopjes01 kernel: [628490.171408] Node 0 DMA32: 561*4kB (UME) 596*8kB (UME) 489*16kB (UME) 307*32kB (UME) 147*64kB (UE) 56*128kB (UME) 8*256kB (UE) 0*512kB 0*1024kB 1*2048kB (M) 0*4096kB = 45332kB
Oct 26 20:32:16 knopjes01 kernel: [628490.171429] Node 0 Normal: 205*4kB (UME) 826*8kB (UMEH) 851*16kB (UMEH) 349*32kB (UMEH) 106*64kB (UME) 6*128kB (UM) 3*256kB (UM) 0*512kB 0*1024kB 0*2048kB 0*4096kB = 40532kB
Oct 26 20:32:16 knopjes01 kernel: [628490.171449] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=1048576kB
Oct 26 20:32:16 knopjes01 kernel: [628490.171451] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
Oct 26 20:32:16 knopjes01 kernel: [628490.171453] 18922 total pagecache pages
Oct 26 20:32:16 knopjes01 kernel: [628490.171454] 1373 pages in swap cache
Oct 26 20:32:16 knopjes01 kernel: [628490.171455] Swap cache stats: add 15206450, delete 15204909, find 10714917/13328576
Oct 26 20:32:16 knopjes01 kernel: [628490.171457] Free swap  = 0kB
Oct 26 20:32:16 knopjes01 kernel: [628490.171458] Total swap = 4194300kB
Oct 26 20:32:16 knopjes01 kernel: [628490.171459] 2076047 pages RAM
Oct 26 20:32:16 knopjes01 kernel: [628490.171461] 0 pages HighMem/MovableOnly
Oct 26 20:32:16 knopjes01 kernel: [628490.171462] 62047 pages reserved
Oct 26 20:32:16 knopjes01 kernel: [628490.171462] 0 pages hwpoisoned
Oct 26 20:32:16 knopjes01 kernel: [628490.171463] Tasks state (memory values in pages):
Oct 26 20:32:16 knopjes01 kernel: [628490.171464] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
Oct 26 20:32:16 knopjes01 kernel: [628490.171471] [    480]     0   480    72368     6879   110592        0         -1000 multipathd
Oct 26 20:32:16 knopjes01 kernel: [628490.171476] [    481]     0   481     6399      447    73728      455         -1000 systemd-udevd
Oct 26 20:32:16 knopjes01 kernel: [628490.171480] [    504]   101   504     4061      458    73728      219             0 systemd-network
Oct 26 20:32:16 knopjes01 kernel: [628490.171484] [    715]   102   715     6381      403    90112      980             0 systemd-resolve
Oct 26 20:32:16 knopjes01 kernel: [628490.171487] [    727]   104   727    22338      556    73728      196             0 systemd-timesyn
Oct 26 20:32:16 knopjes01 kernel: [628490.171490] [    745]     0   745     1101      458    45056       40             0 cron
Oct 26 20:32:16 knopjes01 kernel: [628490.171493] [    747]   103   747     2230      562    53248      133          -900 dbus-daemon
Oct 26 20:32:16 knopjes01 kernel: [628490.171497] [    752]     0   752    31977      652   151552     5858             0 firewalld
Oct 26 20:32:16 knopjes01 kernel: [628490.171500] [    758]     0   758     7567      960    98304     1947             0 networkd-dispat
Oct 26 20:32:16 knopjes01 kernel: [628490.171503] [    760]   999   760    82956     2020   143360     3289             0 nx584_server
Oct 26 20:32:16 knopjes01 kernel: [628490.171507] [    763]   113   763    55600      521    81920      346             0 rsyslogd
Oct 26 20:32:16 knopjes01 kernel: [628490.171510] [    769]     0   769     8560      763   110592     3655             0 supervisord
Oct 26 20:32:16 knopjes01 kernel: [628490.171513] [    770]     0   770    12082      540    90112      234             0 systemd-logind
Oct 26 20:32:16 knopjes01 kernel: [628490.171516] [    772]     0   772    30845      525    90112      179             0 thermald
Oct 26 20:32:16 knopjes01 kernel: [628490.171519] [    775]   999   775   241191    25509  4272128     6278             0 zwavejs2mqtt
Oct 26 20:32:16 knopjes01 kernel: [628490.171522] [    790]   109   790     4357     1054    77824      272             0 mosquitto
Oct 26 20:32:16 knopjes01 kernel: [628490.171525] [    809]     0   809     3855      526    73728      358         -1000 sshd
Oct 26 20:32:16 knopjes01 kernel: [628490.171528] [    810]     0   810    13799        1    98304      414             0 nginx
Oct 26 20:32:16 knopjes01 kernel: [628490.171532] [    812]    33   812    13963      447    98304      499             0 nginx
Oct 26 20:32:16 knopjes01 kernel: [628490.171535] [    813]    33   813    13963      447    98304      499             0 nginx
Oct 26 20:32:16 knopjes01 kernel: [628490.171538] [    814]    33   814    13963      447    98304      499             0 nginx
Oct 26 20:32:16 knopjes01 kernel: [628490.171541] [    815]    33   815    13963      418    98304      464             0 nginx
Oct 26 20:32:16 knopjes01 kernel: [628490.171544] [    835]     0   835      798      209    45056       30             0 agetty
Oct 26 20:32:16 knopjes01 kernel: [628490.171547] [    883]     0   883    26780      839   114688     2067             0 unattended-upgr
Oct 26 20:32:16 knopjes01 kernel: [628490.171550] [    892]   110   892  1498815    30131  3522560   361586             0 mariadbd
Oct 26 20:32:16 knopjes01 kernel: [628490.171553] [    897]   111   897    53928      711   159744      608          -900 postgres
Oct 26 20:32:16 knopjes01 kernel: [628490.171556] [    902]   111   902    53965      903   323584      631             0 postgres
Oct 26 20:32:16 knopjes01 kernel: [628490.171560] [    903]   111   903    53928      124   155648      648             0 postgres
Oct 26 20:32:16 knopjes01 kernel: [628490.171574] [    904]   111   904    53928       96   147456      648             0 postgres
Oct 26 20:32:16 knopjes01 kernel: [628490.171578] [    905]   111   905    54069      532   155648      683             0 postgres
Oct 26 20:32:16 knopjes01 kernel: [628490.171582] [    906]   111   906    17616      172   126976      633             0 postgres
Oct 26 20:32:16 knopjes01 kernel: [628490.171585] [    907]   111   907    54035      146   147456      690             0 postgres
Oct 26 20:32:16 knopjes01 kernel: [628490.171588] [   1047]     0  1047    58621      482    86016      237             0 polkitd
Oct 26 20:32:16 knopjes01 kernel: [628490.171592] [   1085]  1001  1085     7770      683   102400     3538             0 gunicorn
Oct 26 20:32:16 knopjes01 kernel: [628490.171595] [   1124]  1001  1124    24001      749   245760    12504             0 gunicorn
Oct 26 20:32:16 knopjes01 kernel: [628490.171598] [   1130]  1001  1130    24001      631   245760    12507             0 gunicorn
Oct 26 20:32:16 knopjes01 kernel: [628490.171602] [   1131]  1001  1131    24001      648   245760    12509             0 gunicorn
Oct 26 20:32:16 knopjes01 kernel: [628490.171605] [   1132]  1001  1132    24001      739   245760    12511             0 gunicorn
Oct 26 20:32:16 knopjes01 kernel: [628490.171608] [   2385]     0  2385    73239      537   155648      682             0 packagekitd
Oct 26 20:32:16 knopjes01 kernel: [628490.171611] [ 137066]   999 137066    83782     1715   176128     7131             0 esphome
Oct 26 20:32:16 knopjes01 kernel: [628490.171615] [ 143896]   999 143896   176801      554  1425408     4736             0 npm start
Oct 26 20:32:16 knopjes01 kernel: [628490.171618] [ 143908]   999 143908      722      189    40960       25             0 sh
Oct 26 20:32:16 knopjes01 kernel: [628490.171622] [ 143909]   999 143909   241959    16228  3428352     4240             0 node
Oct 26 20:32:16 knopjes01 kernel: [628490.171625] [ 170867]  1001 170867    31618     3738   307200    16238             0 python3
Oct 26 20:32:16 knopjes01 kernel: [628490.171628] [ 227251]     0 227251   366644     1923   258048      718          -900 snapd
Oct 26 20:32:16 knopjes01 kernel: [628490.171631] [ 227526]   108 227526     5546      917    81920      575             0 snmpd
Oct 26 20:32:16 knopjes01 kernel: [628490.171634] [ 232051]   999 232051  3097303  1807740 20131840   565595             0 hass
Oct 26 20:32:16 knopjes01 kernel: [628490.171638] [ 300227]   111 300227    54382     1464   200704      526             0 postgres
Oct 26 20:32:16 knopjes01 kernel: [628490.171641] [ 300237]  1001 300237    29144    17553   282624        0             0 python3
Oct 26 20:32:16 knopjes01 kernel: [628490.171645] [ 300586]     0 300586     6329     2792    81920        0             0 apport
Oct 26 20:32:16 knopjes01 kernel: [628490.171648] [ 300621]     0 300621     5773      852    86016        0          -250 systemd-journal
Oct 26 20:32:16 knopjes01 kernel: [628490.171651] [ 300637]   111 300637    54165      707   155648      534             0 postgres
Oct 26 20:32:16 knopjes01 kernel: [628490.171654] [ 300638]   111 300638    54067      869   155648      534             0 postgres
Oct 26 20:32:16 knopjes01 kernel: [628490.171657] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/system-home\x2dassistant.slice/[email protected],task=hass,pid=232051,uid=999
Oct 26 20:32:16 knopjes01 kernel: [628490.171821] Out of memory: Killed process 232051 (hass) total-vm:12389212kB, anon-rss:7230960kB, file-rss:0kB, shmem-rss:0kB, UID:999 pgtables:19660kB oom_score_adj:0
