High peaks in power meter
I use an IR-reader (from Hichi) at my power-meter at home for all 3 phases. It works great in home-assistant.
But at phase 1 (only here) high power-peaks sometimes occur. Thus, the automatic calibration of the Y-axis is extremly high, up to some million kw. Therefore the regular power values can no longer be seen in the graph.
Is there any idea, how to limit the Y-axis scaling in home-assistance to defined values, manually ?
For example: max = 4.000 Watt, min = -500 Watt.
I have little knowledge in these area …
Thanks in advance
Werner
It would be a better idea to fix your sensor.
Do you know why these spikes occur?
