tekHudson
(Tek Hudson)
March 28, 2024, 12:14pm
1
I am running Home Assistant OS on
Dell OptiPlex 7050 Micro PC Core i7-7700T 3.6 GHz 32GB DDR4 1TB SSD
and i’ve started noticing the fan running like crazy! Please help me make sense of this. I have Terminal installed and have been trying other unix commands to no avail. Is this an actual terminal? is HAOS an actual version of unix? I’m sorry just confuzed
attached are the TOP and stats from system monitor
francisp
(Francis)
March 28, 2024, 12:29pm
2
No, it is a minimal Linux OS designed to run a bunch of docker containers. While Linux was designed to resemble Unix, it is not actually Unix.
Troon
(Troon)
March 28, 2024, 1:21pm
3
top
is showing 95% but none of the listed processes is even rounding up to 1%. Press 'p'
and it should sort by processor usage.
tekHudson
(Tek Hudson)
March 28, 2024, 1:46pm
4
done with no change to the order on the screen, the top refreshes with slightly different values but it’s all still 0%
tom_l
March 28, 2024, 2:04pm
5
Do you have the CPU speed integration installed?
If so remove it.
tekHudson
(Tek Hudson)
March 28, 2024, 3:04pm
6
I don’t think so, I checked CPU Speed - Home Assistant and dont think it is. it’s not on my integration list, could it be a child installation of another integration? I do have system monitor System monitor - Home Assistant
tekHudson
(Tek Hudson)
March 28, 2024, 5:17pm
7
Additional info from htop
Not seeing high total percentage any more but still don’t know whats use it all
tekHudson
(Tek Hudson)
March 28, 2024, 7:03pm
8
I think i found the culprit
tekHudson
(Tek Hudson)
March 29, 2024, 1:35pm
9
That’s not an addon bug… VSCode is a CPU hog no matter how you run it. Always has been.
tom_l
March 29, 2024, 11:35pm
11
Try disabling the Home Assistant config helper extension in VSCode and see if that makes any difference.
tekHudson
(Tek Hudson)
March 30, 2024, 6:17pm
12
Do people just turn it off when not in use then?
tekHudson
(Tek Hudson)
March 30, 2024, 6:18pm
13
-Attempting will update-
Updtate: my extensions doesn’t show any extenstions installed
francisp
(Francis)
March 30, 2024, 6:23pm
14
Add-ons I’m not using (but might) are turned off until needed. Including ESPHome, File-editor, Portainer, TasmoAdmin etc…
I don’t, and I’m nowhere near your CPU usage (4vcpus on a Intel Silver 4110)
