High RAM Usage
I installed home assistant on my nuc and the ram usage was pretty good like 1.6 gig with 43 zigbee devices and many automations. Out of nowhere the server started to use a lot of ram like 3.5gb. I tought it was because I updated the server. But I did restore a backup and the problem was still there. I disabled everything at the supervisor like nodered and zigbee2mqtt but i dont see big diffrences.
Does someone have a idea to where to look for? I don’t see weird things in the logs.
im in the same boat right now, on the left is stats from withing HASS and the right is from proxmox. which one is accurate? why is it significantly different?
Does the HASS stats inclusive of all the resources used by addons?
Any Progress worth mentioning?
This is my Memory Usage since installing as a VM in proxmox.
Rebooting the VM sets it back to around 1.75 GB which I suppose to be “normal”.
Haven`t done any more research on my system - searching in the forum i found this thread to be the latest
Will watch for memory usage in the Plugins, once it has risen again …
(running on a beelink n100 with 16GB of RAM - dedicated 6GB for HAOS)
Exactly same problem, here: same machine but 9GB RAM dedicated to HAOS.
I am not a Linux Freak … but I found one site
Linux Ate My RAM
which explains that it has to do with disk swapping and that despite linux shows low RAM everything is fine. (Well it is running fine for a year …)
