Highest humidity room name
I’ve got 8 switchbot temp. sensors (one in each room) where I’d like to get the room name and humidity of the highest registered humidity.
I read that you could get the value by using the min/max value, but not sure how to find the area from that sensor if that’s even possible?
Thanks!
Try this to get a room name & max value:
{% set SET =
     states.sensor |
     selectattr('attributes.device_class','defined') |
     selectattr('attributes.device_class','eq','humidity') |
     list
  set MAX =
    SET |
    map(attribute='state') |
    map('float',default=0) |
    list |
    max
{% set AREA =
     SET |
     selectattr('state','eq',MAX|string) |
     map(attribute='entity_id') |
     map('area_id') |
     list
   )[0]
Hope someone will reduce it to one line)))
P.S. Does not account a “several values have same max value”.
For this - do not use “[0]”, process a whole list.
P.P.S. Do not forget to exclude entities related to an outdoor weather from the “SET” variable.
I would suggest you use a “Combine the State…” (aka Min/Max) Helper to get the Max value. Then you can use it’s attributes to get the area name:
{{ area_name(state_attr('sensor.example_max_humidity', 'max_entity_id')) }}
While this does require that you add new sensors manually
