Hello everyone,
my energy meter is running very well with ESPHome and the modbus configuration.
but one thing is an impossible challenge for me. How can I reset the meter value?
The adress which I have to reset is:
Adress:
0008h-0009h | export energy
000Ah-000Bh | import energy
And the value to write is 0
function code 16 (0x10)
here my code which is not working:
esphome:
friendly_name: ESP32testMB
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "blalvlvl"
ota:
password: "blabla"
wifi:
ssid: !secret wifi_ssid
# If you use Home Assistant please remove this `mqtt` section and uncomment the native `api` component!
mqtt:
broker: 192.168.1.3
#username: !secret mqtt_username
#password: !secret mqtt_password
uart:
tx_pin: 16
rx_pin: 17
baud_rate: 9600
stop_bits: 1
modbus:
#send_wait_time: 500ms
#flow_control_pin: 5
modbus_controller:
- id: epever
## the Modbus device addr
address: 0x1
modbus_id: modbus1
setup_priority: -10
update_interval: 5s
- platform: modbus_controller
modbus_controller_id: epever
register_type: holding
address: 0x000C
unit_of_measurement: "V"
value_type: U_WORD
accuracy_decimals: 1
filters:
- multiply: 0.1 #1/10
address: 0x000D
unit_of_measurement: "A"
value_type: U_WORD
accuracy_decimals: 2
filters:
- multiply: 0.01 #1/100
address: 0x000E
unit_of_measurement: "W"
value_type: S_WORD
#accuracy_decimals: 2
#filters:
#- multiply: 0.01 #1/100
address: 0x000F
unit_of_measurement: "var"
value_type: U_WORD
#filters:
address: 0x0010
#unit_of_measurement: "var"
value_type: U_WORD
filters:
- multiply: 0.001 #1/1000
address: 0x0011
unit_of_measurement: "Hz"
value_type: U_WORD
filters:
address: 0x0000
unit_of_measurement: "kWh"
value_type: U_DWORD
filters:
address: 0x0008
value_type: U_DWORD
filters:
address: 0x000A
value_type: U_DWORD
filters:
switch:
#https://community.home-assistant.io/t/schneider-iem3155-energy-meter-sending-modbus-custom-command/444952/4
custom_command: [ 0x01, 0x10, 0x00, 0x0a, 0x00, 0x02, 0x04, 0x00, 0x00 ]
#text_sensor:
# - name: "rtc_clock"
# platform: modbus_controller
# modbus_controller_id: epever
# id: rtc_clock
# internal: true
# register_type: holding
# address: 0x000c
# register_count: 3
# raw_encode: HEXBYTES
# response_size: 6
#switch:
# - platform: modbus_controller
# id: reset_to_fabric_default
# name: "Reset to Factory Default"
# register_type: coil
# address: 0x15
# bitmask: 1
regards and thanks
Martin
Gaudi
(Gaudi)
April 20, 2023, 12:34pm
3
Hi, you may want to take a look at the great work @rodgon81 has done (esphome/esphome/components/dxs238xw at dev · rodgon81/esphome · GitHub ). His integration has an action to reset the total energy. I have used it and it has reset the meter counter on my DDS238-4 W.
Commands passed by built in ESP8266 may be similar.
Regards
Done with this code for my DDS238-2 ZN/S:
switch:
modbus_controller_id: rs485
address: 0
write_lambda: |-
ESP_LOGD("main","Modbus Switch incoming state = %f",x);
// return false ; // use this to just change the value
payload.push_back(0x04); // device address!
payload.push_back(0x10);
payload.push_back(0x00);
payload.push_back(0x02);
payload.push_back(0xe2);
payload.push_back(0x63);
return true;
Thank you for this hack.
It works for a DDS238-1 ZN. I took some register address from @martin8310
esphome:
friendly_name: ESP-EnergyMeter
esp32:
board: esp32dev
# board: wemos_d1_mini32
framework:
type: arduino
# Enable logging
logger:
level: DEBUG
api:
encryption:
key: "ABC"
ota:
password: "ABC"
wifi:
ap:
ssid: "Esp-Energymeter Fallback Hotspot"
password: "ABC"
captive_portal:
web_server:
port: 80
uart:
tx_pin: GPIO16
rx_pin: GPIO17
baud_rate: 9600
stop_bits: 1
data_bits: 8
parity: NONE
modbus:
send_wait_time: 250ms
disable_crc: False
uart_id: mod_uart
flow_control_pin: GPIO25
modbus_controller:
- id: modbus_device
address: 0x01
modbus_id: mod_bus
setup_priority: -10
update_interval: 30s
command_throttle: 0ms
modbus_controller_id: modbus_device
name: "Total Energy Low"
address: 0x000
register_count: 0 #Much faster & stable readings
unit_of_measurement: "KW"
internal: true
filters:
- multiply: 0.1
name: "Total Energy High"
address: 0x001
register_count: 1 #Much faster & stable readings
internal: true
filters:
- multiply: 0.1
name: "Current Total Energy"
lambda: |-
return (id(Energy_Low).state + id(Energy_High).state);
name: "Current Export Energy Low"
address: 0x008
register_count: 8 #Much faster & stable readings
internal: true
filters:
- multiply: 0.1
name: "Current Export Energy High"
address: 0x009
register_count: 9 #Much faster & stable readings
internal: true
filters:
- multiply: 0.1
name: "Current Total Export Energy"
lambda: |-
return (id(Export_Energy_Low).state + id(Export_Energy_High).state);
name: "Current Import Energy Low"
address: 0x00A
register_count: 10 #Much faster & stable readings
internal: true
filters:
- multiply: 0.1
name: "Current Import Energy High"
address: 0x00B
register_count: 11 #Much faster & stable readings
internal: true
filters:
- multiply: 0.1
name: "Current Total Import Energy"
lambda: |-
return (id(Import_Energy_Low).state + id(Import_Energy_High).state);
address: 0x00C
register_count: 12 #Much faster & stable readings
filters:
- multiply: 0.1
address: 0x00D
register_count: 13 #Much faster & stable readings
accuracy_decimals: 3
filters:
- multiply: 0.001
address: 0x00E
register_count: 14 #Much faster & stable readings
filters:
- multiply: 0.01
address: 0x00F
register_count: 15 #Much faster & stable readings
unit_of_measurement: "KVAR"
filters:
- multiply: 0.01
address: 0x010
register_count: 16 #Much faster & stable readings
unit_of_measurement: "kVA"
filters:
- multiply: 0.001
address: 0x011
register_count: 17 #Much faster & stable readings
filters:
- multiply: 0.01
- platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
name: "WiFi Signal dB"
update_interval: 120s
entity_category: "diagnostic"
device_class: signal_strength
- platform: copy # Reports the WiFi signal strength in %
source_id: wifi_signal_db
name: "WiFi Signal Percent"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "%"
device_class: ""
binary_sensor:
- platform: status
text_sensor:
- platform: wifi_info
ip_address:
ssid:
bssid:
mac_address:
name: Mac Wifi Address
scan_results:
name: Latest Scan Results
dns_address:
switch:
- platform: safe_mode
name: "Restart (Safe Mode)"
- platform: restart
address: 0x01
write_lambda: |-
payload.push_back(0x01); // device address!
return true;
How do you handle Low and High registers for calculations. For example: In many GitHub examples, Total Current Energy = Current Enery Low + Current Energy High. I don’t know if I’m adding them correctly
lambda: |-
Thank you all
