My camera configuration for HikVison with ONvif was working good but with the last updates stopped working
There are these errors (I am sure the credentials are correct).
Couldn’t connect to camera ‘HIKVISION DS-2CD2023G0-I’, please verify that the credentials are correct. Error: Invalid data
22:43:26 – (ERRO) ONVIF
The date/time on HIKVISION DS-2CD2023G0-I (UTC) is ‘2022-08-20 22:43:34+00:00’, which is different from the system ‘2022-08-20 21:43:26.037429+00:00’, this could lead to authentication issues
You have error in logs telling you that you have time/date mismatch. Probably your camera is set to 0 UTC and comp on +1 UTC. Try put your cammera in the same time zone as comp.
I have a doorbell camera from hikvision also connected to a poe switch. I integrated it to ha using frigate. And its accesable on local lan as switch is connected with lan cable to a router.
