Hikvision & Dahua cameras
Hi
Locally I have access to Hikvision & Dahua cameras and want to use it with Home Assistant.
Before I make the purchase I would like to know if any of the two types Cameras. ( Hikvision & Dahua ) will work with Home Assistant and if any of these two makes will have problem with Home Assistant.
I would appreciate your help so that I can purchase the cameras to add to my POE switch. ( Tenda 8 Port PoE TEF1110P-8-102W)
There is no component specific for these cameras but I am sure that both has onvif and as such will work in HA
Hi
Thanks for your reply , not sure what onvif is but will look it up and try understand it. Appreciate your help.
Onvif is a protocol that almost all ip cameras can use nowadays. There is a component in HA for it.
Check the manual for the cameras
Just checked. Hkvision support it but it is desabled by default
Thanks Yuran for the help, much appreciated.
I’ve got a bunch of hikvision cameras they work a treat.
Im using Dahua 4MP domes at home using the ffmpeg component and they work flawlessly
Got a couple of dahua cameras integrated into HA using the Onvif component. works fine
I have several Hikvision cameras and with Home Assistant you can also use the field detection, line crossing and motion detection to trigger events or just view when they were triggered. I only use the default camera component but could use either ONVIF or FFMPEG if you want a live video stream.
Thanks guys for the help, appreciate it.
Can you maybe share your config for the Onvif component that connects to a Dahua camera? I do not get it working.
Thanks!
  • platform: onvif
    host: 10.0.0.4
    port: 80
    profile: 1
    user: ‘user’
    password: ‘password’
I have a Hikvision NVR with Hik and Dahua cams (POE).
I personally use this for HA this to get the cam feed, works great:
  - platform: generic
    still_image_url: http://192.168.1.149:65004/ISAPI/Streaming/channels/1/picture
    name: Ext entrée maison
    username: admin
    password: !secret hikvision
    authentication: digest
Plus with the hikvision binary sensors, HA sees the cam motion and advanced detections (that you can use in HA automations as well:
If your Dahua cams support IVS events you can use a python script to send notifications via MQTT to HomeAssistant. That’s what I do with my Dahua 5231 starlights.
Thanks for the fast response :slight_smile: !
After some debugging it’s slightly working. I found out that when I disable authentication for ONVIF in the settings of the camera it’s working. This is of course not the solution.
Used config:
camera:
  • platform: onvif
    host: 192.168.1.2
    port: 80
    profile: 1
    username: admin
    password: password
But then I get the following error:
2018-12-30 11:34:06 DEBUG (SyncWorker_9) [homeassistant.components.camera.onvif] Connecting with ONVIF Camera: 192.168.1.2 on port 80
2018-12-30 11:34:06 DEBUG (SyncWorker_9) [suds.xsd.query] (‘GetProfiles’, ‘http://www.onvif.org/ver10/media/wsdl’), found as: <Element:0x7f89cf9a43c8 name=“GetProfiles” />
2018-12-30 11:34:06 DEBUG (SyncWorker_9) [homeassistant.components.camera.onvif] Couldn’t setup camera ‘ONVIF Camera’. Error: Unknown error: (400, ‘Bad Request’)
After turning off the authentication I will see in the log that it will use the following URL to connect:
rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=1&unicast=true&proto=Onvif
When this was working, I was hoping that I could use the PTZ functions using a service. But this was not working. So for now, enabled authentication and using the ffmpeg platform with rtsp url.
I use this one:
rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0
I have btw a Dahua DH-SD42C212T-HN
Try removing the profiles part, the camera may not support them.
Just tried it, but still a bad request.
2018-12-30 12:58:18 DEBUG (SyncWorker_8) [homeassistant.components.camera.onvif] Connecting with ONVIF Camera: 192.168.79.45 on port 80
2018-12-30 12:58:18 DEBUG (SyncWorker_8) [suds.xsd.query] (‘GetProfiles’, ‘http://www.onvif.org/ver10/media/wsdl’), found as: <Element:0x7f87a56d03c8 name=“GetProfiles” />
2018-12-30 12:58:18 DEBUG (SyncWorker_8) [homeassistant.components.camera.onvif] Couldn’t setup camera ‘ONVIF Camera’. Error: Unknown error: (400, ‘Bad Request’)
Any chance you can share your Dahua config as well please? I only see Hikvision one in your post.
Were you able to send Dahua events to HA as well?
Also, is there a way to turn off the camera from HA, for the indoor cameras for example?
Thanks!
This PR fixes the bad request stuff on several ONVIF cameras:
Let’s hope it gets accepted soon :slight_smile:
