Hi @juan11perez
I’m well thanks. Just tried it on my DS-KB6403-WIP (It was on my to do list, thanks for the nudge
Unfortunately I get this:
Can't locate the url
You?
Hi @juan11perez
You?
Thank you. I have a DS-KB6003.
Same result. No url.
I’ve got an older Hikvision KB8112-IM doorbell. The open gate command is different according to this REST API reference.
Here is what worked for me:
curl --digest -u admin:pass -X PUT -d '<RemoteOpenDoor version="2.0" xmlns="http://www.isapi.org/ver20/XMLSchema"><gateWayIndex>1</gateWayIndex><command>unlock</command><controlSrc>src</controlSrc></RemoteOpenDoor>' http://<door_bell_ip>/ISAPI/VideoIntercom/remoteOpenDoor
Quick reference how to set up an “open gate” door button:
switch:
- platform: command_line
switches:
open_gate_door:
command_on: >
I hope somebody will find this reference usefull.
All ISAPI info is here:
For those of you using MotionEye, it is possible to use a webhook (instead of mqtt)
Sensor:
sensors:
frontdoormotion_sensor:
value_template: "{{ is_state('input_boolean.motiondoorcam', 'on') }}"
friendly_name: Front Door Motion Sensor
device_class: motion
Automation;
alias: Front Doorcam motion detected
description: ''
- platform: webhook
webhook_id: doorcam
condition: []
entity_id: input_boolean.motiondoorcam
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
- service: input_boolean.turn_off
mode: single
initial_state: true
