The last update isn’t working here. If I try to start, it crashes and I got the following error:
Beta??
Can you try to enable debug and show me logs? Crate issue on github
Yeah. Beta.
I restore to last version, the 3.0.0-beta.39 and everything is ok. How can I enable debug?
Like this:
log_level: DEBUG
sdk_log_level: DEBUG
in your addon condif
Can you create issue on GitHub? And paste log there
Yep. I’ll do that
Can you try beta 43?
Yep! I’ll try
It’s working now.
can you show me the debug log again?
i have installed hikvision-doorbell:3.0.5-amd64 in docker on a synolgy ds218+ and did the config as in the picture.
I want to use it as standalone with the MQTT Broker on my iObroker. My doorbell is DS-KV8113.
But it doesn’t work. Here is something from the logfile:
can someone help?
Can you show me the config with the env?
container:
config:
PATH /usr/local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
LANG C.UTF-8
GPG_KEY A035C8C19219BA821ECEA86B64E628F8D684696D
PYTHON_VERSION 3.10.8
PYTHON_PIP_VERSION 22.2.2
PYTHON_SETUPTOOLS_VERSION 63.2.0
PYTHON_GET_PIP_URL https://github.com/pypa/get-pip/raw/66030fa03382b4914d4c4d0896961a0bdeeeb274/public/get-pip.py
PYTHON_GET_PIP_SHA256 1e501cf004eac1b7eb1f97266d28f995ae835d30250bec7f8850562703067dc6
PYTHONFAULTHANDLER true
LD_LIBRARY_PATH /app/lib-amd64
SYSTEM_SDK_LOG_LEVEL DEBUG
SYSTEM_LOG_LEVEL DEBUG
MQTT_PASSWORD ******
MQTT_USERNAME user
MQTT_HOST 192.168.178.2
DOORBELLS [{"name": "OUTDOOR STATION", "ip": "192.168.178.204", "port":8000,"username": "admin", "password": "******"}]
MQTT_PORT 1885
you only typed 1 underscrore , it must be 2
check here for inscuctions…
oh
so i try it now. At my first try i had problems because i switch all underscore to 2, but than i see that the first underscore is 2 and the second 1
i try to change the port but it doesent work… is it not possible? Always default 1883?
indeed, its fixed for 1883 for now, i need this fix be implemented first:
I have a “standalone” outdoor station (KD8003) integrated with Asterisk server using SIP protocol.
I’m curious if I could resign from SIP and start using other methods described in this thread?.. or maybe I have to stay with SIP as the others require configuration with indoor station to work properly?
3.0.8 added with mqtt port option for standalone containers!
Due to structural constraints I installed a 2-wire unit composed of three elements:
- 2-wire controller, not sure about model, likely DS-KAD706-P, supplies power and links the other devices together into an internal network
- External unit DS-KD8003-IME2
- Internal monitor DS-KH6320
only the controller has a network port but it’s not linked to my network at the moment, the internal monitor has wifi and is on my network, that’s the one I’m trying to access, but I don’t know if I’m doing it right or if I’m supposed to have the controller as a target, if any of these are even supported
I can access the internal monitor through the iVMS-4200 desktop application, I have a working admin password that allows me to change the settings from within the application
This is what I get in the logs if I try to connect through the HA Addon with the same user and password:
2023-09-29 16:16:41.810 | DEBUG | __main__:main:31 - Importing Hikvision SDK
2023-09-29 16:16:41.817 | INFO | sdk.utils:loadSDK:44 - Using OS: Linux with architecture: aarch64
2023-09-29 16:16:41.818 | DEBUG | sdk.utils:loadSDK:57 - Loading library from lib-aarch64/libhcnetsdk.so
hpr tls index{3}
2023-09-29 16:16:41.850 | DEBUG | __main__:main:35 - Hikvision SDK loaded
2023-09-29 16:16:41.851 | DEBUG | sdk.utils:setupSDK:86 - Initializing SDK
loop[2] find 2 mac and 0 ip
[2023-09-29 16:16:41.880][DBG] CCoreGlobalCtrlBase::LoadDSo, HPR_LoadDSo Succ, Path[/lib/aarch64-linux-gnu/libz.so.1.2.11], hHandleRet[-1537182144]
[2023-09-29 16:16:41.880][INF] The COM:HCCoreBase ver is 6.1.4.15, 2020_03_05. Async:1.
[2023-09-29 16:16:41.880][INF] The COM:Core ver is 6.1.8.101, 2021_12_10. Async:1.
[2023-09-29 16:16:41.880][INF] This HCNetSDK ver is 6.1.8.101 Ver 2021_12_10.
2023-09-29 16:16:41.881 | DEBUG | sdk.utils:setupSDK:100 - SDK initialized
2023-09-29 16:16:41.881 | DEBUG | doorbell:__init__:46 - Setting up doorbell: door
2023-09-29 16:16:41.882 | DEBUG | doorbell:authenticate:53 - Logging into doorbell
[2023-09-29 16:16:41.883][INF] Login dev 192.168.100.111:8000.
[2023-09-29 16:16:41.883][INF] dwTotalNum[2048]
[2023-09-29 16:16:41.885][INF] Private connect 192.168.100.111:8000 sock=7 this=0xa49b86b4 cmd=0x10000 port=58942
[2023-09-29 16:16:41.885][INF] LogonDev1 in[192.168.100.111:8000]
[2023-09-29 16:16:41.886][DBG] CCoreGlobalCtrlBase::LoadDSo, HPR_LoadDSo Succ, Path[/app/lib-aarch64/libcrypto.so], hHandleRet[-1532943888]
[2023-09-29 16:16:41.888][DBG] CCoreGlobalCtrlBase::LoadDSo, HPR_LoadDSo Succ, Path[/app/lib-aarch64/libssl.so], hHandleRet[-1532942624]
[2023-09-29 16:16:41.888][INF] SSLTRANSAPI::LoadAPI, libeay, Load Real Path[/app/lib-aarch64/libcrypto.so]
[2023-09-29 16:16:41.888][INF] SSLTRANSAPI::IsAllAPILoaded, SSL_library_init Unload
[2023-09-29 16:16:41.888][INF] OpenSSL, Not All Function Loaded!
[2023-09-29 16:16:41.888][INF] SSLTRANSAPI::PrintVersion, OpenSSL version info [OpenSSL 1.1.1i 8 Dec 2020]
[2023-09-29 16:16:41.888][INF] CSSLTrans::SSLCtxInit, dwSSLVersion[6], m_fnTLSServerMethod
[2023-09-29 16:16:42.746][ERR] [192.168.100.111:8000]PRO_LoginHikDevice fail[err=154].[0x-0000001,0x-0000001]
[2023-09-29 16:16:42.747][ERR] CMemberMgrBase::AllocIndex2, MemberStart Failed, iIndex[0]
2023-09-29 16:16:42.748 | ERROR | __main__:<module>:101 - Error while logging into door: The user index is Invalid. Error code:154
[2023-09-29 16:16:42.780][INF] COM_Logout[-1][1]
Any idea what to do, if it’s possible to integrate with this model at all?
Error 154 means : invalid user id… what username are you using for your indoor station? The default is “admin” ?
That’s interesting, I JUST tried to change the name to something else like “root” and had an error about invalid username, I changed to “admin” again… and now it works
I have no idea why it didn’t before, maybe I had admin capitalized or there was some whitespace, now I have all the entities in HA, so I’m going to play around with it and see if it’s actually working
I have all these entities:
I need to figure out how to get a notification when the doorbell rings now…
but it doesn’t appear I have a notification event or anything, would that mean I’d have to connect to the external unit too?
