Can i edit the extension and pjsip files?
Hi, this is the thread for the addon, not asterisk
Hello to all,
I am using this integration with this device DS-KV9503.
I am the opinion, that the integration supports this device too and I get most of the entities only the motion entity is missing.
The documentation describes that motion is supported.
What can I do to get this motion entity?
Thank your for your help.
There is no motion entity, it’s a device trigger, you can build an automation using device triggers
I played around with an automation and I recognized that “Motion detected” is
available.
Thank you for your help.
Thank you @pergola.fabio. I’ve added a WAV file following this instruction. I made sure it is 8KHz, mono 16bit as detailed however no luck.
All my SIP functionality is working so I can only assume my FreePBX settings are right. Any idea where else to search for a solution?
Hi guys! I don’t know if this is the right place, but I will post my question here. I have bought the kv6113-wpe1(c) and it’s very nice. But, is it possible to disable the entering in AP mode after a long press of the doorbell?
Hi everybody!
I have following intercom configuration:
- KD8003
- KH6320
Both connected with POE switch in internal home network.
Is it possible to receive notification for not closed for given time (15s)? In some old manuals I saw such option “Upload alarm for not closed door”, but I cannot find it in current setting options for KD8003 (in iVMS 4200).
Also I tried to use Hik Connect App, but I didn’t receive such alarm as well.
It’s indeed limited , I believe only one event is possible, door open or door not open, you need to enable it in ivms…
from the add-on log file I can trace when someone opens the door via the intercom pin code. What sensor does this update and how can I use it to trigger an automation?
2024-12-06 15:25:50.041 | INFO | mqtt:update_door_entities:300 - Door 1 unlocked by 112117981081059900 , updating sensor and device trigger
2024-12-06 15:25:50.041 | INFO | mqtt:handle_device_trigger:487 - Invoking device trigger automation{'name': 'Door unlocked', 'type': 'door open', 'subtype': 'door 0', 'payload': {'control_source': '112117981081059900'}}
It’s no sensor entity, it’s a device trigger, you can build it on those…
not sure what you mean… do I need to build a trigger based on the specific mqtt message {'name': 'Door unlocked', 'type': 'door open', 'subtype': 'door 0', 'payload': {'control_source': '112117981081059900'}}
or is there a specific device trigger that I can use?
ahh… I already have several automations utilizing the device buttons (e.g.: switch.intercom_door_relay_0) but I’m not sure how to get the explicit device status of when someone keys in the pin code and opens the intercom… I assume the below will trigger when anytime the door is open / not necessarily just when the pin code is keyed.
Hmm , on the door switch, there is an attribute called “control_source” that should give some unique id who opened the door
not showing up… weird.
not sure I’ll be able to code it in if its not part of the device - do you happen to have a yaml example?
No , sorry , I don’t have an example
If you just want an automation when door is opened, why not just use the door switch entity?
I already have that automation working with switch.intercom_door_relay_0
for when I want to open or open & close from home via Home Assistant
I’m looking for something else: I want to toggle switch.intercom_door_relay_0
3 minutes after the door opens by someone keying in the door pass code so I can close the door after someone came in.
Hello to all,
I have a DS-KV9503 and I would like to get the information, when somebody pressed the “doorbell button” and the doorbell is ringing, but I did not get the information. I would like to use the doorble is ringing information to play a sound on a media player. I do not want to install a classic bell.
In my lookfile there is no information visible when I press the doorbell button.
In a post above I found this screenshot, where “doorbell ringing” is visible.
So it seems that I do something wrong
I have checked all events in the automation but only the “motion” and “door 1 relay” is triggered.
Can somebody help?
Thank you.
