Yes, I see it for control commands, but for status request, it does not update.
For control I see the “request” and “response” under “hmd/text/IndoorScreen/ISAPI-request/attributes”
But for status request, it does not populate, just stays on last OPEN/CLOSE request.
2024-12-16 16:25:10.759 | INFO | mqtt_input:_isapi_input_callback:505 - Received input text for doorbell: IndoorScreen
2024-12-16 16:25:10.769 | ERROR | mqtt_input:_isapi_input_callback:528 - Error while invoking ISAPI endpoint: ('Error while calling ISAPI /ISAPI/SecurityCP/status/outputStatus?format=json', 23, 'Device does not support this function.')
[2024-12-16 16:25:10.769][DBG] SimpleSTDCommandToDvr with out cmd[POST /ISAPI/SecurityCP/status/outputStatus?format=json], input size[90], max segment length[262144]
Also, any chance you could add a few lines of code to update the hmd/switch/IndoorScreen/Com-1-relay/state in the case an isapi status request is sent?
Even if I can get the “attributes” to populate, it still needs regex analysis, which is not possible with the mqtt plugin for homebridge.
The attribute should be filled, can you test again with debug enabled on the container? It should be there too…
The attribute is just an output, it’s filled with whatever json/XML comes from the device… It can be whatever you ask… so not sure how I can template it?
Do you want me to update the switch?
Isn’t it better that I don’t define the switch to always OFF , so you can send ON and OFF ?
2024-12-16 17:15:45.280 | INFO | mqtt_input:_isapi_input_callback:505 - Received input text for doorbell: IndoorScreen
2024-12-16 17:15:45.291 | ERROR | mqtt_input:_isapi_input_callback:528 - Error while invoking ISAPI endpoint: ('Error while calling ISAPI /ISAPI/SecurityCP/status/outputStatus?format=json', 23, 'Device does not support this function.')
[2024-12-16 17:15:45.291][DBG] SimpleSTDCommandToDvr with out cmd[POST /ISAPI/SecurityCP/status/outputStatus?format=json], input size[90], max segment length[262144]
But it actually does work when tested through hik-connect
I mean the isapi command does work through hik-connect (using https://apiius.hik-connect.com/v3/userdevices/v1/isapi). So if Hik-connect is passing status request using isapi, how would the actual indoor station not support it?
