aah thank you so much, I was being silly, I had added it to my custom sensors.yaml when I see there is a binary_sensors.yaml file which I should have added.
This now works. Thank you very much.
I assume this will only be to access camera events?
How does one show the actual video footage on their dashboard?
The above integration is only for sensors via any preconfigured hikvision alarm triggers.
There are multiple different ways to add cctv video streams to home assistant and it’s a large subject, however the first thing you will need to do is discover your RTSP address to access the cameras.
Ok awesome, Then once I have established that what do I do?
Will this then work when I am not home? I assume not due to the local rstp IP address or will HA dashboard be smart and re-stream it up via the cloud link?
