seagri
(Sean)
October 19, 2022, 9:51am
21
I have added this in configuration.yaml:
binary_sensor:
- platform: hikvision
host: 192.168.1.234
username: !secret hikvision_username
password: !secret hikvision_password
So this will be ON when there is motion.
To enable some logs try this:
logger:
default: info
logs:
pyhik: debug
But I’m not sure…
Can you get the video into HA?
But it could be that your cameras is not supported…
Then maybe you could also try this one
if the cameras supports it. Mine does but I have not tried it.
HAS_Phil
(Phil)
November 8, 2023, 11:50am
24
I have problems setting up hikvision integration.
DS-7716NXI-I4 / 4S
I can get the list of devices, but no events are received. Maybe this is a problem of alarm server settings?
Alarm Host-IP: 10.0.9.110 (Home Assistant)
Alarm Host Port: 8123
Multicast-Address: ???
Enable virtual host?
Enable flow control?
What did you need to change to get this working? Ive got exwctly the same issue. Using Hikvision Next integration, i get everything, feels, sensors, etc. But no smart events.
Alarm server set to internal ip port 8123 path /api/hikvision
Using port forward, local cert.
