Hello
i am looking to buy used Hilo thermostat (telpro allia), my main question is “are they compatible with HomeAssisant”
i just need to see temperature, and adjust them with HA?
Do i need a ZigBee bridge?
Andre
Hello
Andre
The answer is yes you can use it with HA. It may or may not work using ZHA but it’s supported by zigbee2mqtt (Stelpro Hilo Thermostat HT402 Zigbee compatibility).
You will need a Zigbee coordinator: I personnaly have the following (Sonoff Zigbee 3.0 EFR32MG21 Dongle Plus-E ZBDongle-E Zigbee compatibility) plugged into my computer running HA.
Thank you so much, i will order a Zigbee 3.0 EFR32MG21
Hello
is there a way to get the Humidity value in HA?
i got the Stello thermostat in HA
That’s not possible as the thermostat itself doesn’t publish the humidity reading. There might not even be a humidity sensor in the thermostat. See Stelpro HT402 control via MQTT | Zigbee2MQTT for available data.
Hello again…i got my Hilo thermostat added to HA, To get the electricity usage do i need to be a Hilo customer?
If you’re using Zigbee2MQTT, it should already be available. I don’t know if ZHA provides it. If not you might need to create an energy sensor yourself. Frequently Asked Questions about home energy management - Home Assistant
I’m wondering… I have Hilo and the 3 years contract will end soon. However, I made some comparisons and it’s with Hilo that I get the better return. Compared with Flex D and Winter credit.
So, I’d like to keep getting Hilo benefits, but also move my thermostats to HA. I’d keep my Hilo router to get total consumption.
Anyone here know if that’s allowed ? If I create similar automations in HA as those from Hilo (or even better), I guess that counts as participating ?
Anyone have done that ?
Thanks !
@vgibara Did you find a solution for that? I am looking for the same exact thing
