Hi,a new company is starting in my region and there price are really good since they try to have more client
I was wondering if I could integrate it in home assistant
The Hilo thermostat seems to be the a rebranding of Stelpro Maestro SMT402 so it should be working with Zigbee2MQTT add-on.
Iâll keep you up to date, Hilo will be installing the system at our home at the end of october.
On peut maintenant intégrer Hilo à Google home! Il faudrait seulement une intégration pour Home assistant semblable à Wemo ou Kasa par exemple et nous pourrions avoir nos thermostats dans home assistant
Des nouvelles sur ça ?
I have hilo thermostats running for nearly a month now
I too have 9 âHiloâ thermostats at home. What would you say be the best way to run everything locally without the need of relying on the Hilo cloud? Getting something like a ZigBee dongle with a raspberry Pi could work but I am just wondering how complicated it would be to setup?
Working with a zigbee dongle would work, but we would not be able to use the Hilo cloud with it. You would have to choose between the two, and I would choose using the Hilo cloud to make sure I participate to the Hilo challenges.
I have a custom integration that work since 2 months. I am able to get datas from thermostats and update the target temperature.
I am also able to retrieve power data from the energy meter since yesterday.
Here is my custom integration:
My code is awful, but it seems to work, for nowâŠ
Really cool and nice work.
In my case, I actually need to ditch the hilo service because I am moving to another house with central heating. I do plan however to keep some of the thermostats for the basement and garage.
That is why I was asking about connecting them directly to home assistant.
I do agree that if you have a hilo service at home, you should use the integration you developed for sure since it would not be possible to bind the thermostats to two different zigbee networks.
BR,
Mathieu
Then I would go with * zig-a-zig-ah! (CC2652 Stick)" with Zigbee2MQTT add-on, it should work I think.
You can test my Hilo integration:
Let me know how it works for you.
Salut, Je me demandais si vous pouviez me donner votre opinion / experience avec Hilo
Est-ce que ça vaut la peine ? Est-ce que les dĂ©fi sont dur Ă respectĂ© ? Est-ce quâil y a des coup supplĂ©mentaire ? des coup mensuel ??
Merci
Salut,
je lâai depuis 2 mois donc jâai encore eu aucun dĂ©fis vu que câest lâhiver.
Mais aucun cout supplĂ©mentaires ni cout mensuel. Lâimplantation en elle meme est super facile, branchement a HASS super facile grace a la lib. Les gars de hilo tâinstalle ca en une demi journĂ©e, trĂšs rĂ©actif, sont meme revenu tout reinstallĂ© car les thermostats Ă©tait mauvais mais je le savais.
Comme je dis Ă mes amis, jâai hate Ă lâhiver pour essayer ça !
Just went through the thread and I am still on the fence with ordering Hilo and I have a few questions:
After the 3 years amortization, can the hub be released from Hilo and be fully controlled locally from HA instead of cloud control? Is that hub only a cloud connected device configured through the Hilo/Stelpro app but also controllable using Francisâs integration? Aware a USB dongle is not that expensive but would be great not having to reset the network and dump a 130$ hub.
I am using the custom component for Lutron Caseta with a pro bridge and its been perfect for a few years now so moving away from that seems like asking for trouble but getting 4 free Hilo installed zigbee devices seems a good deal. I could run a hybrid home and get a few switches that are not yet smart.
Anyone using the Enbrighten dimmers on LED and halogens and are they good at minimum load and are they buzzing when dimmed? I have an array of 7 ceiling halogen lights (50 watts per light) and my current smart dimmer works great.
Sorry to necro this thread , since they are very aggressive now âŠ
3 to 5 thermostat + other stuff for 199âŠ
I like to have my stuff local, so i dont think i will be able to use ilo + HA at same timeâŠ
all my ZB are manged via Z2M
Also after a year of usage from many of you , what is your feedbackâŠ
Hi, you can have Hilo and use HA using this non official integration(but it will still be dependent of the cloud): GitHub - dvd-dev/hilo: Home Assistant Hilo Integration via HACS Thereâs currently few persons having some problem but things should be sorted out before winter begin! It was working like a charm last year.
Iâve put all the dimmer they gave me on my personnal Zigbee network and Iâve let the thermostat on the zigbee Hilo platform. I removed any scene or schedule from the Hilo app and thanks to the hilo integration, I was able to create allsort of automation in HA. I managed to get a check of around 350$ for the last winter.
Hi, Same for me ! light with zigbee integration and thermostat with hilo cloud integration. I created my own automation and same have about 300$ of cash back at the end of summer ! I Recommend Hilo for every one but even more if you have Home Assistant and can manage it by yourself !
Thereâs really nothing complex with those automation.
Hereâs a simple example of an automation that trigger when the challenge start.
alias: TEMP - DĂFI Hilo en cours Extra audacieux
description: ""
- platform: state
entity_id: sensor.defi_hilo
to: reduction
condition: []
- scene: scene.defi_hilo_en_cours_extra_audacieux
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- service: remote.send_command
device_id: xxxxxxxxxxxxxxxxxxxxx
device: thermopompe
command: heat25off
num_repeats: 3
delay_secs: 2
- service: script.heat_25_off
data: {}
mode: single
The scene called cut the power off few devices and lower the temp of every piece in the house to 16c and turn off my heat pump.
Hereâs the automation that trigger after a challenge to bring back temp and devices to normal state.
alias: TEMP - DĂFI Hilo - Recovery jour travail sans enfants
description: ""
- platform: state
to: recovery
condition:
- condition: time
after: "09:58"
before: "11:00"
weekday:
- mon
- tue
- wed
- thu
- fri
- condition: state
entity_id: input_boolean.journee_pedago_routine_desactive
state: "off"
- scene: scene.defi_hilo_recovery_jour_travail_sans_enfants
device_id: xxxxxxxx
device: thermopompe
command: heaton23
num_repeats: 3
delay_secs: 2
mode: single
Simply put, you just trigger your automation based on the state of the entity sensor.defi_hilo and do wathever you want with that depending on your activity, if you are in the house etc⊠You can manage the pre_heat phase too, so you can level up the temperature before a challenge to stay comfortable during that time.
Better late than never I guess⊠Hereâs my two cents.
After 3 years, you can just stop using hilo and switch to HQ winter credit if itâs available at your home. You will have the right to hook all the devices to your zigbee network and manage everything by yourself as I understand this. But if you stop using Hilo youâll loose the consumption of your house because itâs provided by the hilo hub.
You might be able to use both, canât help with that.
Canât say how they work with halogen light but Iâm really not a big fan of those dimmer⊠Theyâre really hard to dimm to a precise %, I had problem with at least one of them stopping responding and I wasnâT able to turn off the light at all no matter what I tried.
