i just bought rfxcom and tries to install that. however, the integrationhttps://www.home-assistant.io/integrations/rfxtrx/ is not available when i search the list in hass.io to add an integration.
so how should i force install this?
Which home assistant version are you running?
armv7-hassio-cli:2020.10.1
|HASSIO|172.30.32.2|
|SUPERVISOR|172.30.32.2|
I meant core version. Latest is 0.117.1. Check this in Configuration --> Info
arch | armv7l |
chassis | |
dev | false |
docker | true |
docker_version | 19.03.13 |
hassio | true |
host_os | Raspbian GNU/Linux 10 (buster) |
installation_type | Home Assistant Supervised |
os_name | Linux |
os_version | 5.4.51-v7l+ |
python_version | 3.8.6 |
supervisor | 2020.10.0 |
timezone | Europe/Amsterdam |
version | 0.117.1 |
virtualenv | false |
dashboards | 1 |
mode | storage |
resources | 0 |
views | 5 |
What are those strange characters you are searching on?
In your screenshot its showing some strange characters after rfx?
What if you dont use filter and scroll down to find it?
Maybe a cache issue as it works for me. Ctrl-f5
it wasn’t listed there.
this helped. at least (after a restart of the server) it’s now installed.
