Hisense add on is failing, can't find logs
I am trying to set up the HiSense add on from GitHub - deiger/AirCon: Scripts for controlling Air Conditioners, e.g. with HiSense modules. but the server keeps stopping and I can’t find anything in the logs to explain why. I’ve checked the main Home Assistant logs, the supervisor logs, and the log tab for the add on.
I’m running Hassio on a Raspberry Pi 3, I’ve set up MQTT and configured the add-on as per the instructions. It starts OK but I can’t connect to it using the curl command in the instructions (connection refused) and Supervisor is always noting that it’s stopped.
Any guidance as to where to find the error logs are appreciated.
