Hisense air conditioner integration in Home Assistant using AEH-W4E1 wifi module.
Does anyone have any information on this?
yes please :))
maybe you can work with GitHub - deiger/AirCon: Scripts for controlling Air Conditioners, e.g. with HiSense modules.
I’ve tried it today… it was a little bit tricky and the documentation is ??? also tricky if you do not know anything about hiSense, mqtt - so you have to guess some values.
e.g. with the “webserver” is meant the local integration installation, normally at port 8888? Not sure, but at me works …
Good luck
