Believe me or not, it has started working now…didn’t change anything, just tried again…
Sorry for the annoyance !
And thanks for the work !
EDIT: well, no, it doesn’t work.
the switch is reported as inactive although th TV is ON
Adding a card with that switch and trying to click on it has absolutely no effect on the TV.
And I do not understand how to use the other entity (media player)
EDIT2: it “kinda” works…
I have to run the app on my phone to see the card being enabled in HA.
Then I can quit the remote app.
But as soon as I switch off the TV from HA with the switch, when I switch it on with my physical remote, HA is not updated (the switch stays off), and I have to run the app again to update the switch state…
Any idea what I am doing wrong ?
Yep, it works as long as RemoteNow is opened on my phone.
As soon as I close the app, it looks like connection is lost…
Very strange, and no help from the integration author…
EDIT: after a bit of troubleshoot, it looks like the broker needs to be woken up by the app if the TV goes from OFF to ON. Then it works as intended, as long as the TV is not turned OFF.
@lindsayward I’ve found where was my problem, TV Fastboot was disabled, and when disabled the broker does not start with the TV when you switch it on…
@sehaas I’ve another problem now…WOL does not work. It is enabled on the TV and I’m on ethernet connection. I can switch off the TV, but can not switch it on.
Any idea ?
No one has mentioned where this goes really, is this in the config.yaml file?
EDIT: update
so after messing around with hisensetv api for python, i am able to power on and off my projector using the api but i cant get it working in home assistant
thanks for the reply! considering the python api doesnt require ssl do you still think that could be the issue? i dont have a mosquitto folder under share
i own a Hisense H55U8B and i want to integrate it in HA, in this topic i find many ways which confuses me a little.
Is there a kind of a howto for starters to integrate the TV?
Hi Everyone, There’s some great work here, thank you! I’ve run into a little trouble in configuration and I was hoping to get some advice from the collective brains-trust.
I’ve been using the ha_hisense_tv library posted by @sehaas (installed as a custom repository via HACS) and following along with some of the instructions on Home_Assistant_Hisense_TV originally posted by @danzal, however I run into an issue obtaining the certfile from the TV, I get the following error:
CONNECTED(00000003)
write:errno=54
no peer certificate available
No client certificate CA names sent
SSL handshake has read 0 bytes and written 293 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
The mosquitto log also shows the same error others have observed when they are missing a certificate:
I’m not hugely familiar with handling certfiles like this so any suggestions would be greatly appreciated!
[edit]
I should add that remote control with the (iOS) RemoteNow app does work (except to turn the TV on, which appears to have been reported a few times on the app store. Attempting to connect using MQTT Explorer fails (validate certificate off and TLS encryption on) with a non-specific “Disconnected from server” error.
Hi guys, I’ve read and re-read this whole thread dozens of times and tried every possible combination of config setting and using the correct certificates etc to no avail. I can however connect over MQTT explorer perfectly. I think half the issue is that we’re running different hisense models that need varying degrees of authentication. Can I get one of you fine people to check my screen shots and show me where I am getting this wrong.
Hi!
Don’t know if this might help as it could be as you said it depends on the TV model, but just in case you want to double check this is my working config:
It works pretty good (sometime you have to unplug the TV from the power because it hangs, but it doesn’t happen so often. Right now I’m only struggling to find a reliable way to create a binary sensor that tells me when it’s really on or off.
Hey
I see there are a couple ways to get Hisense TVs into HA.
Is there a advice which is the best?
To me the: https://github.com/sehaas/ha_hisense_tv lookedmost promising.
I just don’t find it as repo in HACS when I search for Hisense
