Hello, awhile ago I disabled history and logbook to save space on the sd card. Everything works cool. I did try a few times to re-enable the tools but am not able to. I can not remember what steps I took to disable them, seems to me it was more than just commenting the entries in config.yaml.
Now, I am getting invalid config messages and would like to fix it despite the fact it all still works., I had even done a complete fresh install a few months ago and because I backed up to my old data, of course somehow it still does not work.
The error message I receive is:
Invalid config
The following integrations and platforms could not be set up:
In addition to Nick’s and my previous advice, please see the documentation. You are using an outdated key, base_url that has been replaced with internal_url and external_url that now both reside under homeassitant:
Thank you for the information , it was not what was needed but I still did benefit by getting the external url corrected.
Updated to 112 and was still not working but I noted that 112 focussed on logbook and history so I did some reserach and lucked out. I located the correct db file, looked into it, nothing there, i deleted it, reboot and Voila, back to normal.
Hi, I’m getting exactly the same problem. Up to date on versions (I too tried moving to 112 but didn’t help).
I get “invalid config” for recorder, logbook, history and default_config as well as the recorder could not start notification. Just the same as you reported.
Can you let me know how you fixed it? What db file did you delete?
Same issue here - renamed the db file (just in case) and after a reboot all good again. No doubt the schema had changed in the previous update - kinda annoying that wasn’t picked up but what the hey. All good now.
