If I disable the History option by removing it from my configuration.yaml file (but leave the recorder in place) to disable the side panel history will this also remove history from more info pop-up dialogues?
The answer is no. Removing the history but keeping the recorder removes both the sidebar and the more-info display information. However, the data in the database is retained so re-enabling history puts everything back to as it was before disabling it.
