julesilve
(jules)
February 23, 2024, 1:51pm
1
Hi HA Forum.
Hopefully this is an easy question.
Currently I can go to History, pick an entity and time range and download the data.
Is there a way to automate this process on an hourly or daily basis?
AND possibly append the data to the csv file?
Any help is greatly appreciated.
tom_l
February 23, 2024, 1:56pm
2
Not that I know of. But you can write the data to a csv file as it occurs.
See the example lower down.
julesilve
(jules)
February 23, 2024, 4:26pm
3
Hi Tom. Thanks for that. I did try this before and did not manage to get the syntax right in config.yaml
I inserted the sections in yellow but yaml configuration complained:
tom_l
February 23, 2024, 9:40pm
4
You are missing a dash in front of platform: file
Also please don’t post pictures of text. Post the actual text correctly formatted for the forum. See section 11 of the FAQ.
julesilve
(jules)
February 24, 2024, 8:06am
5
Thanks Tim for pointing out my error. That has saved perfectly now. I would have posted text but I wanted to annotate to clarify my issue. I will bear that in mind in future.
In the mean time I have found that using Node Red to “export” sensor data was slightly simpler using 3 nodes.
