In my previous version (2021.8.3) the history graph that I had set up was showing the same style of graph as is shown in the “history” tab (not sure what that display type is called).
it looked similar to this:
the values in that graph are on/off but the values that I was displaying were numeric but it still looked the same as above.
but the history graph is now treating them as if they have a unit of measurement even tho they don’t (I removed all but one sensor for clarity - there were many more as in the first image above):
I don’t have a screenshot of how it looked before.
I looked in the changes for this release and didn’t see anything related to the history graph card.
Did I miss something or is this undocumented?
Is there any way to revert this graph to display as it did prior to this update? I don’t see any option for graph style in the docs.
Actually, my numeric states ALWAYS looked like the line chart UNLESS I gave it a unit of measurement, like “Unit” or “Level”, then I get a state graph instead
So I can change it back by forcing it to a non-numeric UOM? thanks, I’ll give that a try.
Normally I wouldn’t worry about it since I would usually want my numbers on a numeric graph but I was trying to compare two different values (on/off of one entity vs 1/0 of a different entity) on a time basis and then this suddenly happened.
Strange that my experience was exactly the opposite tho. it was a state graph until I just updated yesterday.
I’m not sure if the UOM is something just added to those sensors with the latest update. I assume it is since it worked “fine” (for my use case) right before my update and then it didn’t.
I know for a fact there is no other UOM customization - at least until I just added one as I tried to do above to fix it.
