So I’m finally jumping in on the lovelace bandwagon after just using the default setup for the last few years. The only thing I’m having troubles with so far, is that I have a power switch that also reports consumption; I want to have a graph of the power consumption for this switch, but if I use history_graph, I seem to only be able to graph the on/off state.
Reading the docs doesn’t seem to have helped, so is there a way to generate a graph for an attribute of an entity, and not just the default “on/off” that it shows?
Fair enough. I’ve been using node-red for automations for a while now, and it makes accessing these attributes trivial without adding the extra templates
