History Graph - MQTT Sensor / Showing last value when sensor is offline
Hello!
I have several mqtt sensors and I don’t like the behaviour of the history graph card. When a sensor is offline, I would like to see NO data points. I can’t find out the right setting. It is even possible?
In the picture you see the data form a solar inverter. When the inverter/sensor is offline, HA shows a straight line. When HA is shut down, there are no data points = what I want.
Reloading the HA tab, it shows always a new data point with the last known value of the sensor. What I’m missing?
Thank you!
Here my simple sensor setting:
mqtt:
       - name: "MIC Power22"
         state_topic: "energy/solar"
         unit_of_measurement: "W"
         value_template: "{{ float(value_json.MIC_Power) }}"
Update: I added “expire_after: 20” - but the history graph on every reload shows a data point with the actual time an the latest value.
