History-Graph showing no state history
Hello all, i recently moved my home assistant server over to my FREENAS server. I was using an older version of homeassistant that still used the history_graph: in the configuration.yaml. So now i am trying to add the history graph card in lovelace, but no matter what sensors I add as entities, it says No State History Found. I have tried deleting the database, but still the same issue. Any thing obvious i should check? I should mention, that the sensors I am adding are also in a group that is being displayed, and the temperatures are being displayed, and there is a state history for them. Thanks!
If you are running 0.109 you have to remove the purge interval from the recorder config.
Thanks for the reply. So in my config i just have recorder:
I don’t have any purge settings.
Did you restart after deleting the db?
Yes, restarted service, and also restarted the jail. Database recreates successfully but same behavior.
Any other ideas? Im at a loss.
Finally figured it out. I did not have history: in my config. I was not in my old config for 0.94.1.
I have your same problem but i’ve not resolve. any
suggestion
I don’t have a problem.
Look at your logs.
