VdR
April 6, 2023, 10:43am
1
Several history graphs have started to show extra entities that are not defined to show up.
Definition:
Shown on the dashboard:
This occurs on multiple history graphs, it is always the same extra items (the five presence sensors) that show up.
When I deleted the whole history graph and define from scratch these extra entities show up again.
Not sure what to try next.
Some people reported similar issues.
I suggest you to register an issue on GitHub.
I myself observed a similar problem in my setup, that was a bit different issue.
opened 11:28PM - 03 Jun 22 UTC
closed 11:15PM - 07 Jun 22 UTC
integration: recorder
### Checklist
- [X] I have updated to the latest available Home Assistant ver… sion.
- [X] I have cleared the cache of my browser.
- [X] I have tried a different browser to see if it is related to my browser.
### Describe the issue you are experiencing
Create a history-graph with TWO entities:
- sun.sun (which is supposed to be included in the Recorder)
- any other entity (which was excluded from Recorder)
Let's create a sensor w/o a History:
template:
- sensor:
- name: service_zero_value
icon: mdi:null
state: '{{ "0" }}'
recorder:
exclude:
entity_globs:
- sensor.service_zero_value
The card:
type: history-graph
entities:
- entity: sun.sun
- entity: sensor.service_zero_value
hours_to_show: 24
The output:
![изображение](https://user-images.githubusercontent.com/71872483/171966414-f5648c43-e1b4-49e4-b92d-677a565af4e1.png)
**The card contains TWO same another entities - which were not selected.**
### Describe the behavior you expected
If some selected entity does not have a history - then it is NOT displayed on the graph.
No any other entities are displayed, except selected entities with a history.
### Steps to reproduce the issue
1. Create a sensor w/o history.
2. Create a card.
### What version of Home Assistant Core has the issue?
HA 2022.6.1
### What was the last working version of Home Assistant Core?
_No response_
### In which browser are you experiencing the issue with?
Chrome 102.0.5005.63
### Which operating system are you using to run this browser?
Win10x64
### State of relevant entities
_No response_
### Problem-relevant frontend configuration
_No response_
### Javascript errors shown in your browser console/inspector
_No response_
### Additional information
_No response_
VdR
April 8, 2023, 9:42am
3
Thank you for that link.
This forum is fantastic. I have struggled with this issue for weeks, 10 minutes after I posted, probably before anybody had even seen my post, the problem disappeared.
I had just updated the HA core to 2023.4.0 and the button card if I recall correctly. No idea if that is related to the magical fix.
You restarted HA - it probably helped.
And this is NOT a fix.
The issue is still there since some people faced it.
Suggest you to register an issue.
VdR
April 8, 2023, 2:53pm
5
I had restarted HA dozens of times before without an effect. There must have been something more. Thus far the issue has not returned. Fingers crossed.
Seems you have not registered an issue… Wait & hope then.
