For a few days the history graphs weren’t showing anything at all.
Today I tried restarting via Developer Tools/Yaml/Restart/Restart Home assistant
After restarting I had a series of errors in the log and the history graphs are just showing “History integration disabled”
Error evaluating condition in 'V_count_very_low': In 'condition': In 'template' condition: ValueError: Template error: float got invalid input 'unknown' when rendering template '{{states('sensor.filtered_voltage') | float < 194.5 }}' but no default was specified
1:20:00 PM – (WARNING) Automation - message first occurred at 11:50:00 AM and shows up 30 times
Template variable warning: 'None' has no attribute 'state' when rendering ';{{ now().strftime("%d-%m-%Y %H:%M")}},{{states.sensor.filtered_power_grid.state}},{{states.sensor.filtered_voltage.state}},{{states.sensor.filtered_power_prism.state }},{{ state_attr('sun.sun', 'elevation') }},{{ state_attr('sun.sun', 'azimuth') }}'
1:20:00 PM – (WARNING) helpers/template.py - message first occurred at 11:50:00 AM and shows up 30 times
Error while executing automation automation.sensor_values_to_file_leam: Error rendering data template: TemplateError: Invalid entity ID 'sensor.filtered_power_grid_Leam'
1:20:00 PM – (ERROR) Automation - message first occurred at 11:50:00 AM and shows up 10 times
sensor_values_to_file_Leam: Error executing script. Error for call_service at pos 1: Error rendering data template: TemplateError: Invalid entity ID 'sensor.filtered_power_grid_Leam'
JSON result was not a dictionary
12:55:52 PM – (WARNING) MQTT - message first occurred at 12:55:52 PM and shows up 2 times
Error initializing 'Protect 60A fuse' trigger: In 'numeric_state' condition: unknown entity sensor.filtered_equo_current
11:44:26 AM – (WARNING) Home Assistant Core Integration
Error while processing template: Template<template=({{states('input_number.amp_limit')|float-(states('input_number.prism_corrente'))|float/1000}}) renders=2>
11:44:26 AM – (ERROR) helpers/template.py - message first occurred at 11:44:26 AM and shows up 4 times
Error initializing 'template' trigger for 'Conservatory hot': ValueError: Template error: float got invalid input 'unknown' when rendering template '{{states.sensor.shelly_ht_temp.state|float>states.sensor.cucina_temperature.state|float+1}}' but no default was specified
11:44:26 AM – (WARNING) Template - message first occurred at 11:44:26 AM and shows up 2 times
TemplateError('ValueError: Template error: float got invalid input 'unknown' when rendering template '{{states('input_number.amp_limit')|float-(states('input_number.prism_corrente'))|float/1000}}' but no default was specified') while processing template 'Template<template=({{states('input_number.amp_limit')|float-(states('input_number.prism_corrente'))|float/1000}}) renders=4>' for attribute '_attr_native_value' in entity 'sensor.errore_corrente'
11:44:26 AM – (ERROR) helpers/template_entity.py - message first occurred at 11:44:26 AM and shows up 2 times
Entity sensor.water_usage (<class 'homeassistant.components.template.sensor.SensorTemplate'>) is using native unit of measurement 'l' which is not a valid unit for the device class ('humidity') it is using; expected one of ['%']; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+template%22
11:44:26 AM – (WARNING) Sensor
Zigbee channel 11 utilization is 93.76%!
11:44:26 AM – (WARNING) components/zha/core/gateway.py - message first occurred at 11:44:26 AM and shows up 2 times
Config entry 'shelly1pm-Fridge' for shelly integration not ready yet: DeviceConnectionError(); Retrying in background
11:44:14 AM – (WARNING) config_entries.py
Setup failed for history: (DependencyError(...), 'Could not setup dependencies: recorder')
11:44:13 AM – (ERROR) setup.py - message first occurred at 11:44:02 AM and shows up 4 times
Unable to set up dependencies of history. Setup failed for dependencies: recorder
Error adding entities for domain sensor with platform command_line
11:44:05 AM – (ERROR) Sensor - message first occurred at 11:44:03 AM and shows up 2 times
Automation with alias 'input amp' could not be validated and has been disabled: template value should be a string for dictionary value @ data['action'][0]['data']. Got {'payload_template': "{{states('input_number.amp')'}}", 'topic': 'prism/1/command/set_current_user'}
11:44:05 AM – (ERROR) Automation
Unable to prepare setup for platform filter.sensor: (DependencyError(...), 'Could not setup dependencies: recorder')
11:44:02 AM – (ERROR) setup.py - message first occurred at 11:44:02 AM and shows up 10 times
Unable to set up dependencies of filter. Setup failed for dependencies: recorder
Setup of recorder is taking longer than 300 seconds. Startup will proceed without waiting any longer
11:43:46 AM – (ERROR) setup.py
Waiting on integrations to complete setup: recorder
11:43:45 AM – (WARNING) bootstrap.py - message first occurred at 11:39:45 AM and shows up 5 times
Setup of recorder is taking over 10 seconds.
11:38:56 AM – (WARNING) runner.py
